Will center section from pre 65 8 3/4 work in 65 and newer #2302514
05/10/17 06:02 PM
05/10/17 06:02 PM
Mid west
C_stripes Offline OP
Mid west
I have heard both, yes and no. Now I need a definitive answer. Will the third member from a 64 8 3/4 with bolt on axles work with the 67 housing with the non bolt on axles?
If not, what stops them from working correctly?
Thanks in advance.
Re: Will center section from pre 65 8 3/4 work in 65 and newer [Re: C_stripes] #2302522
05/10/17 06:13 PM
05/10/17 06:13 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
With stock axle bearings a Sure grip will fit, an open differential will not fit.
Why?
Because the centering block is 1.5" wide on a sure grip and 1965 and newer open rear.
The centering block on a 1964 and older open rear is 1.25" wide.
I can get pictures of each on an assembled 3rd member and you will see how different they are.
Re: Will center section from pre 65 8 3/4 work in 65 and newer [Re: C_stripes] #2302524
05/10/17 06:14 PM
05/10/17 06:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ran a 64 center section in a 69 housing with no problems, non-SG setup
Don't be the exception.
Re: Will center section from pre 65 8 3/4 work in 65 and newer [Re: C_stripes] #2302525
05/10/17 06:17 PM
05/10/17 06:17 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
If you use green bearings it will work because they don't need a thrust block.
Re: Will center section from pre 65 8 3/4 work in 65 and newer [Re: C_stripes] #2302675
05/11/17 12:28 AM
05/11/17 12:28 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Here are pictures, see the difference in the thrust blocks? So now you can easily spot it.
1965 and newer. Thrust block is round and there is space around it.
1964 and older. Thrust block is a large rectangle that fills all the space between the spider gear and side gears. This is narrower where the axles go, 1.25"
