TQ/Intake Selection
#230246
02/20/09 06:02 AM
02/20/09 06:02 AM
Posts: 608 NY
old340dog
NY
I want to use a TQ from demon sizzler for my 340 rebuild. But have noticed that there is not much a selection of intake for carbs with spreadbores. Any suggestions?
old340dog
Re: TQ/Intake Selection
[Re: old340dog]
#230247
02/20/09 09:16 AM
02/20/09 09:16 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
The factory issued ones were not that bad. Biggest disadvantage is the weight.
Common sense is a flower that does not grow in everybody's garden
[Re: Dr-Dave2]
#230249
02/20/09 11:39 AM
02/20/09 11:39 AM
Posts: 826 Stone Mt, GA.
DEMONSIZZLER
super gas
super gas
Stone Mt, GA.
All the above suggestions are good ones. If you have a really mild 318 or 360, the Edelbrock Performer will work well also and has the correct carb pattern to mount a T.Q. You could find a good deal on a used intake on *bay or here on moparts, David.
ThermoQuads:stock, street/strip and race;
800/850 cfm's, 860/910 cfm's and 1,000 to 1,060 cfm's.
New parts for all OEM 1971-1984, Competition Series and SuperQuad carbs and custom fabricating.
Carbs bought and sold. Consulting on pre-purchases
so you get the right carb the first time.
[Re: DEMONSIZZLER]
#230250
02/20/09 08:44 PM
02/20/09 08:44 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
How would the Holley SD do if you opened it up to 360 port size? It will take square bore or spreadbore without an adapter.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: AdamR]
#230252
02/20/09 09:07 PM
02/20/09 09:07 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I have a new Action Plus for sale for $120. PM me if youre interested
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: lemondana]
#230254
02/21/09 04:15 PM
02/21/09 04:15 PM
Posts: 608 NY
old340dog
NY
What difference is there between a performer and a M1 intake?From what I've seen of the M1 it is a single plane. what is the big difference between a single plane and a dual plane intake. I assume both will accept the TQ. Which would be your choice for street use using a TQ?
old340dog
[Re: old340dog]
#230256
02/21/09 04:47 PM
02/21/09 04:47 PM
Posts: 30,556 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
You now saying it is a streeter makes the choice smaller but it still needs more clarification ...
Like car weight, gearing, camshaft, exhaust system ...
PLUS ...is MPG a concern at all ?
[Re: boydsdodge]
#230258
02/21/09 05:32 PM
02/21/09 05:32 PM
Posts: 20,996 A collage of whims
topside
A collage of whims
I used the Eddy Performer on my 406" street 360, port-matched to the heads, and one of Demonsizzler's TQs. VERY responsive, ran great from idle-6000RPM, pulled plenty of vacuum, couldn't be happier. '74 Duster, A/C, Engle 214/224@.050, .470/.504 lift, 9.5:1, cleaned-up (gasket-matched intake side & bowls opened) iron heads, headers, stock A/T & converter, 3.21 gear, 275/60R15 tire, about 3400 lbs empty. 9.5 with iron heads and 91 octane is the edge of detonation in hot weather, though. Had to pull timing out of it but it does 17MPG @ 70, and pulls very strongly for that gear & weight.
[Re: topside]
#230259
02/21/09 06:06 PM
02/21/09 06:06 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
Will the factory gas and trans linkage work with the Performer on a 340 or do you need to buy an adapter?...thanks
Semper Fi
