4x4 to4x2 #29559
09/14/06 07:24 AM
09/14/06 07:24 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
picked up a 4x4 400 Ramcharger a couple of months ago, wasn't going to go this route but in looking the truck over & figureing out what direction to go with it( restore or just beat the crap out off) I found that the front spring mount(front & rear ) were shot everything was either broken or re welded wrong.
Soooo I decided to convert it to 2wheel drive .
so these pics are for those WHO SAY YOU CAN"T DO IT THE FRAMES ARE DIFFERNET. what world are you from...
In the past 12 years I've done 10 trucks this way , this will be 11 ..
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: 4x4 to4x2 [Re: ric3xrt] #29560
09/14/06 07:26 AM
09/14/06 07:26 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
This pic is off the 4x2xmember preped & ready to install, in prepeing these xmember to go in, you MUST REMOVE THE ENGINE MOUNTING PLATES...its not hard, if you realized how badly welded they are from the factory .... we just won't go there.
Re: 4x4 to4x2 [Re: ric3xrt] #29561
09/14/06 07:42 AM
09/14/06 07:42 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
ok last pic for today
Xmember installed , the upper to bolt hole line up perfectly , the 2 in the bottom of the xmeber will not line up , so they have to be redrilled in the frame, not a big deal use 7/16th bolt & your good, I always put a tack weld on all of it anyway ..can't be too carefull
This xmember is out of a 87 Ramcharger , after 88 the xmembers are silghtly different , thats a whole other ballgame
For the more creative & adventious people ... yes you can lower a truck this way by notching the frame 2 inches...don't try 3inch too much crap to over come, its not fot the faint of heart or the mechanically challanged
I have a 77 440 4x4 warlock that I'm going to convert over in october ( I tried to talk the guy out of it , BUT ITS HIS TRUCK) I'll get more indepth with the whole Photo & step by step thing.
And yes this was all done whille the engine was supported by the hoist & yes the rans & transferr caes are still in the truck. they will be removed this weekend.
Re: 4x4 to4x2 [Re: ric3xrt] #29562
09/14/06 03:45 PM
09/14/06 03:45 PM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
WOW GLAD TO SEE SOMEONE ELSE BELIEVES WHAT I BELIEVE !
I am actually considering this with my 75 RC since it is smog excempt, and really like the idea of a 2x4 cruiser with a removeable top.
Good job and hope you keep the pics coming if there are anymore I am interested to see the finished (and in progress) product.
Good Luck
1975 Ramcharger 6" lift 35" Mud Terrains 8 lug 44 front, 60 rear. (R.I.P.)
1976 D100 lowered 3" & 5" Now with a 440!!! (sold)
On the hunt for another beauty to build.
Re: 4x4 to4x2 [Re: ric3xrt] #29563
09/14/06 11:10 PM
09/14/06 11:10 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Thats pretty cool to know. The factory manuals always pointed out that the frames were different. Nice to know a switcheroo is possible.
Sheldon
Re: 4x4 to4x2 [Re: RUNCHARGER] #29564
09/15/06 04:36 PM
09/15/06 04:36 PM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
The only difference that I have noticed is if you are going from 2wd to 4wd as you have to measure and cut the hole in the frame for the shackle mount and add the spring hanger for the front spring, besides swapping in a 4x4 crossmemeber.
Re: 4x4 to4x2 [Re: 3XCHARM] #29565
09/15/06 07:04 PM
09/15/06 07:04 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
oK here the Passenger side with the upper & lower control arms att , & the strut rod xmember installed.
Sunday or monday I'll have the Rotors & brakes..the rotors I bought are 83 small bolt...so after I put them on that should put the mistery to rest.
Re: 4x4 to4x2 [Re: ric3xrt] #29566
10/08/06 09:54 PM
10/08/06 09:54 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
She's on her wheels , with the 400 installed ,
Re: 4x4 to4x2 [Re: ric3xrt] #29567
10/08/06 10:55 PM
10/08/06 10:55 PM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
Lookin Good! I am still up in the air about mine though.
Re: 4x4 to4x2 [Re: RUNCHARGER] #29568
10/08/06 11:23 PM
10/08/06 11:23 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Sheldon
I've seen part numbers change because of one hole drilled different. That could be the reason.
Re: 4x4 to4x2 [Re: Magnum] #29569
10/08/06 11:38 PM
10/08/06 11:38 PM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
Sheldon
I saw a factory thickness chart for frames on this forum for a 1990. The difference from 1/2ton to 3/4ton can vary by as much as 1/8" depending on what wheel base you have.
https://board.moparts.org/ubbthreads/upload2/2964366-DSC00666.JPG
Re: 4x4 to4x2 [Re: Magnum] #29570
10/09/06 06:57 AM
10/09/06 06:57 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Sheldon
The only difference I've seen in 4x4 vs 4x2 is just that where some of the holes are drilled, the upper a arm supports the holes line up with the 4x4 engine xmember but the rest have to be drilled.
The Idler arm holes are not in the 4x4 frame so they have to be drilled, its not that big of a deal, I'll show how to do that when I do this Warlock in the next couple of weeks.
On the trans Xmember the 4x4 uses 3 bolts to mount to the frame the 4x2 uses 2, to use the 4x2 Trans member in the 4x4 you have to use the Middle 4x4 hole as the front hole for the 4x2 & the you have to drill the back hole .
On this truck I had to elongatet ( sp) the holes in the 4x2 trans member, this is the 4th I;ve had to do this to the others lined up perfectly.
Re: 4x4 to4x2 [Re: ric3xrt] #29571
10/09/06 07:00 AM
10/09/06 07:00 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Sheldon
( should clarify that statment) , Only in the 1/2 tons
Re: 4x4 to4x2 [Re: ric3xrt] #29572
10/24/06 09:25 PM
10/24/06 09:25 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Bolted the front end sheet metal on this muttly beast tonight.
Hopefully I can get a couple of runs on this thing yet this year.
Re: 4x4 to4x2 [Re: ric3xrt] #2302217
05/10/17 06:52 AM
05/10/17 06:52 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Totally forgot about this thread.....
any way 1st run, crappy 400 and 727 13.90 @99 mph
last run 451 inch 400, stage 6 heads Huges HEV6368 cam ,Harland rockers
727 4.56s blah blah blah 10.47@129mph at Atco
Re: 4x4 to4x2 [Re: ric3xrt] #2478716
04/07/18 08:35 AM
04/07/18 08:35 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
heard from the current owner , he says it'll be back on the rd this summer , it's now got a 511 inch TF head 440 in it, should run great.
Re: 4x4 to4x2 [Re: ric3xrt] #2478737
04/07/18 09:57 AM
04/07/18 09:57 AM
Guitar Jones Offline
Interesting. I know of many trucks converted from 4x2 to 4x4 but not the other way around.
Re: 4x4 to4x2 [Re: ric3xrt] #2479247
04/08/18 07:53 AM
04/08/18 07:53 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
kind of had a 4x2 Ramcharger Fetish my whole life owned 8 legit Pop Top 4x2s and converted 6.
Re: 4x4 to4x2 [Re: ric3xrt] #2479863
04/09/18 10:50 AM
04/09/18 10:50 AM
scratchnfotraction Offline
HUMM... good info on how its done. thank you! glad it come back up
I am going 4x4 to 4x2 but keeping the front leafs/steering and just replacing the diff with a straight tube axle for a gasser style truck.
I just noticed on the way to work this morning there was a 2x RC for sale..I was thinking great, I just drug home a 86 truck 4x4 chassis 100$ and a 78 new yoker with a 65,000 mile 440/727 100$
I will see what the asking price is today on the RC and may change directions with the project to get that BB gasser RC after all. only got 200$ in the project build so far. that's cheap enough a start.
I should be able to convert the RC 2x chassis to a 4x4 chassis combining the 2 chassis I have now and a 440/727 too boot!
wont have to find a cab/bed/title and already have a set of wheel tubes to tub it for fat tires.
Re: 4x4 to4x2 [Re: ric3xrt] #2479880
04/09/18 11:25 AM
04/09/18 11:25 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
A 4x2 Pop Top Ramcharger with a Big CI 440 , is a blast to drive, body twisting doors popping open.....seriously think about adding some cross bracing in the frame, because of it being a tub as opposed to a cab and Bed. there is a lot more flex.
