Re: 55mm cam bearings
[Re: sgcuda]
#2303473
05/12/17 06:42 PM
05/12/17 06:42 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
I have used 55MM stuff for awhile, and yes sometimes cires are hard to come by. I prefer the roller to the babbit by about a million to one The Predator has a big babbit deal and it SUCKS A$$ to spin over for sure. Just something else we will address next time. As for a roller failure, we had it happen in the Vette last year, was ugly and made a big mess of the block in the process
[Re: Al_Alguire]
#2303478
05/12/17 06:48 PM
05/12/17 06:48 PM
Posts: 4,457 Washington
madscientist
Washington
I have used 55MM stuff for awhile, and yes sometimes cires are hard to come by. I prefer the roller to the babbit by about a million to one The Predator has a big babbit deal and it SUCKS A$$ to spin over for sure. Just something else we will address next time. As for a roller failure, we had it happen in the Vette last year, was ugly and made a big mess of the block in the process We are talking about how much torque it takes to turn an engine over on the stand. What happens when the engine is running and oil is keeping the cam off the bearings? Or, are you seeing signs of the cam getting into the bearings while under load? I'm just curious if the roller bearings show a HP gain when running. Has anyone done and A-B-A test?
[Re: madscientist]
#2303719
05/13/17 07:03 AM
05/13/17 07:03 AM
Posts: 739 Florida
408Dust
I have used 55MM stuff for awhile, and yes sometimes cires are hard to come by. I prefer the roller to the babbit by about a million to one The Predator has a big babbit deal and it SUCKS A$$ to spin over for sure. Just something else we will address next time. As for a roller failure, we had it happen in the Vette last year, was ugly and made a big mess of the block in the process We are talking about how much torque it takes to turn an engine over on the stand. What happens when the engine is running and oil is keeping the cam off the bearings? Or, are you seeing signs of the cam getting into the bearings while under load? I'm just curious if the roller bearings show a HP gain when running. Has anyone done and A-B-A test? Roller can get lubricated by splash/mist, babbit needs a little direct lubrication. I run 54mm babbit with .030 oil feeds to the cam bearings keep rest of the oil on the rods and mains.
[Re: sgcuda]
#2304018
05/13/17 09:33 PM
05/13/17 09:33 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Seems that some one did a dyno test a few years back and came up with roller vs. babbit didn't make that much difference horse power wise for the extra cost involved . If you want every little bit out of your engine than it's a no brainer, go roller.
[Re: sgcuda]
#2304056
05/13/17 10:48 PM
05/13/17 10:48 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Not a matter of what I want to do, or what is best. This is what the block already has. All I need to do now is check if all 5 bearings are the same.
[image][/image]
[Re: rowin4]
#2304294
05/14/17 01:21 PM
05/14/17 01:21 PM
Thumperdart
State of confusion
Seems that some one did a dyno test a few years back and came up with roller vs. babbit didn't make that much difference horse power wise for the extra cost involved . If you want every little bit out of your engine than it's a no brainer, go roller. Power is not the issue or gain it's the load from Hugh ass spring pressures most use in those combos that a roller handles and spreads loads better than babbit...........
