Bergman Auto Craft and Borgeson steering box
#2300821
05/07/17 07:39 PM
05/07/17 07:39 PM
Posts: 3 Norway
TeleThunder
Norway
Hi Just want to share my experience with Borgeson steering box. Just installed one in my 73 Charger. And it was a true bolt in job Everything fitted perfectly. Some people are complaining about the need for shims to line up the new box and steering shaft, but I did not need this. The original box had a very small operating angle. Because the new box is smaller the angle needs to be little bit bigger to point towards the steering column and fit perfectly. But this is taken care of in the design so no shims needed Bought the direct fit coupler from Bergman Auto Craft, so no need for shortening the steering column, just bolt it on My Charger have the big sector shaft and the new pit man arm bolted right on, with the nut fully entering all the threads. I have another Borgeson steering box installed on another car, GM car, and that was also a true “bolt on” box And the customer support and service from Peter and Bergman Auto Craft is just top notch Will try to post some photos later on...
Re: Bergman Auto Craft and Borgeson steering box
[Re: TeleThunder]
#2301100
05/08/17 12:25 PM
05/08/17 12:25 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Well he is from Norway, so we probably can give him some slack.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: TeleThunder]
#2301194
05/08/17 03:05 PM
05/08/17 03:05 PM
Posts: 4,432 Michigan
MarkZ
Worthy
Worthy
I had a similar experience to what the OP had. Is my post count high enough?
[Re: TeleThunder]
#2301332
05/08/17 08:20 PM
05/08/17 08:20 PM
Posts: 12 finland
pade
finland
Parts received exelent service. Thanks
[Re: astjp2]
#2301349
05/08/17 09:00 PM
05/08/17 09:00 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Well he is from Norway, so we probably can give him some slack. He's signed up on ForAbodiesOnly and ForBBodies only as well, no posts there. May not be a big forum guy. I suspect he commented to his supplier how well it went and the supplier asked that he share his experience here. I can't fault either one of them for that.
[Re: TeleThunder]
#2301659
05/09/17 11:46 AM
05/09/17 11:46 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
I ordered my unit from Peter just so I would not have to put up with the issues some have had. When I called him, he was busy but returned my call promptly and was a pleasure to deal with which makes me happy when I spend the bucks. Personal service with knowledge goes along way in my book.
Carl Kessel
[Re: TeleThunder]
#2303351
05/12/17 02:06 PM
05/12/17 02:06 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I have purchased from Peter, A-arms, boxes, power pumps, hoses, pulleys coupler, ect...he even sent me a nice BAC air freshener...
A new iron curtain drawn across the 49th parallel
[Re: GoodysGotaCuda]
#2309710
05/23/17 12:12 PM
05/23/17 12:12 PM
Posts: 3 Norway
TeleThunder
Norway
I used Bergman Autocrafts adapters: AN adapter set: My box already had the brass inserts for flare fitting, they are o-ring type originaly I think. Worked like a charm
[Re: TeleThunder]
#2322570
06/17/17 11:39 AM
06/17/17 11:39 AM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
another A+ for Bergman Autocraft. I bought 2 PS boxes, one for the Cuda and one for the Duster. Top notch service! Now shortly we will test drive the new box.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
