Re: Big block Edelbrock head intake bolt ?
[Re: Belvedere1]
#2300880
05/07/17 10:20 PM
05/07/17 10:20 PM
Guitar Jones
Two things you may or may not want to hear. Fill the flutes of the tap with wheel bearing grease, this will hold the cuttings which probably won't amount to much anyway. Secondly what ever is not caught in the grease is aluminum so it really isn't going to hurt anything. That's what filters are for.
YMMV however so do whatever you are comfortable with.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Belvedere1]
#2301453
05/08/17 11:33 PM
05/08/17 11:33 PM
Posts: 1,361 Wild West
M_D
Wild West
I would second the suggestion to use a form tap, also called a roll tap. That style of tap literally forms threads in malleable materials (most steel, aluminum, brass, copper, etc.) without cutting, they are similar to a screw that extrudes the metal and forms threads. For your application get one that doesn't have flutes and you will have no chips if you lubricate it well.
Besides the obvious advantage of not producing chips it will force the metal back into shape instead of removing it and making the threads weaker and looser. That may not be a big issue unless the threads are really messed up, but it's still the best solution.
