E body gauges #2300685
05/07/17 02:06 PM
05/07/17 02:06 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Non rally dash. I had the dash out to add a oil pressure guage. When reinstalled, the fuel guage is working properly but the temp guage immediately goes to full right when key is turned on. I thought it may be the small VR was damaged however it also poweres the fuel guage and it seems ok. any ideas??
Re: E body gauges [Re: Dr Dave] #2300690
05/07/17 02:16 PM
05/07/17 02:16 PM
Andrewh Offline
Andrewh  Offline
I would look for a ground in the wire to the sending unit. or bad sending unit.
Re: E body gauges [Re: Dr Dave] #2300699
05/07/17 02:34 PM
05/07/17 02:34 PM
Dr Dave Offline OP
Dr Dave  Offline OP
It was working fine prior to dash disassembly. Forgot to mention deleted amp guage and wired in volt guage.
Re: E body gauges [Re: Dr Dave] #2300717
05/07/17 03:09 PM
05/07/17 03:09 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Update, I unplugged the violet wire (sender) from the guage, hit the key and the guage went to full R. I fiddled with the guage mounts and now it seems to be working. The guage must have been grounding out?
Re: E body gauges [Re: Dr Dave] #2300726
05/07/17 03:33 PM
05/07/17 03:33 PM
Andrewh Offline
Andrewh  Offline
that is the most logical idea.
makes me wonder though, how. As I recall, the pegs that go into the circuit board are insulated where they poke out of the dash frame.
I hate to say it, but I would take it out again to see where it might have touched.
If some insulation broke down, or it was missing.
I wouldn't want driving vibration to cause it to ground out again.
Re: E body gauges [Re: Andrewh] #2300792
05/07/17 06:06 PM
05/07/17 06:06 PM
Dr Dave Offline OP
Dr Dave  Offline OP
Good call
