dash paint #229973
02/19/09 08:30 PM
02/19/09 08:30 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
What paint should I use to repaint my dash and steering column. Its for a 73 cuda and it's black. I'm just looking for something I can get in a spray can off of the shelf that will look correct.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: dash paint [Re: 73cuda340] #229974
02/19/09 10:15 PM
02/19/09 10:15 PM
SE Pa.
LimeliteAero Offline
SE Pa.
check with an automotive paint supplier. They should have SEM products that youll want to use. try to get the suede finish....if you cant get it go with the least amount of gloss you can get. black will be easier than us colored dash guys had it.
Re: dash paint [Re: LimeliteAero] #229975
02/19/09 11:05 PM
02/19/09 11:05 PM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
I believe that 1971-later doesn't use suede texture in the dash/column paint.
