Purple shaft question... #1460705
07/01/13 01:57 AM
07/01/13 01:57 AM
Colorado Springs, Colorado
Dartthunder340 Offline OP
I have a .590 for my small block and the lash is recommended to be set at .28/.30 cold. How much can I tighten or loosen this up and be safe? Could someone explain why these are set up to have that much lash in them? Thank you.
Better get inside Ma. Looks like a storm's comin'.
Re: Purple shaft question... [Re: Dartthunder340] #1460706
07/01/13 02:13 AM
07/01/13 02:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I havent run that cam but I do have a roller that calls
for 28/30 lash... right now I have it set at 18/18 with
alum heads... hot
Re: Purple shaft question... [Re: MR_P_BODY] #1460707
07/01/13 10:48 AM
07/01/13 10:48 AM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
I have run it at .016 &.018 with iron heads. Jim
Re: Purple shaft question... [Re: Dartthunder340] #1460708
07/01/13 01:41 PM
07/01/13 01:41 PM
I would try it stock at the track and then tighten it up .003 to .006 at a time to find out which way you want to run it
Re: Purple shaft question... [Re: Cab_Burge] #1460709
07/07/13 02:42 PM
07/07/13 02:42 PM
western PA
Sb Valiant Offline
Sb Valiant  Offline
western PA
I have the .590 cam too and I think the valve lash setting atleast on ours 28/32 was to loose. Will be experimenting with tighter valve lashes and see where it ends up!
Re: Purple shaft question... [Re: Sb Valiant] #1460710
07/07/13 02:46 PM
07/07/13 02:46 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I had good results with both lobes lashed at .018" on both big and small blocks. Made a little more power on the dyno,and faster e.t. at the track.
Keith
Re: Purple shaft question... [Re: Dartthunder340] #1460711
07/21/13 12:07 AM
07/21/13 12:07 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
I run that cam in my 408 and I set it 28/32 and the car is very consistant with that setting and has been problem free.I've heard of racers running them tighter but I just don't want the failure problems.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Purple shaft question... [Re: 77DragracerR/T] #1460712
07/21/13 10:59 AM
07/21/13 10:59 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Why do you think you would have failure problems ?
Re: Purple shaft question... [Re: Dartthunder340] #2299614
05/05/17 04:52 PM
05/05/17 04:52 PM
Hello everyone, hope all is well! I wanted to bump and revisit this. Was wondering if anyone else was running lash different than the .28/.30 Mopar recommendation? I still have my same combo of Aries domed pistons/ open chamber W2's and the .590 Purple Shaft. I did set it to .25/.25 cold and didn't notice any difference. I would like to go a lot tighter (.18/.20?) to see if there would be gains. Do you see any possible issues? Thanks again for your help!
Re: Purple shaft question... [Re: Dartthunder340] #2299621
05/05/17 05:11 PM
05/05/17 05:11 PM
pgh. pa.
lil mope Offline
lil mope  Offline
pgh. pa.
I have the 557 solid on a 360 with eddy heads and runs best at .026 cold across and adds 5 more cranking comp.From 140 to 145. Never had a problem that loose even on turnpike.
Rick
Re: Purple shaft question... [Re: Dartthunder340] #2299937
05/06/17 08:47 AM
05/06/17 08:47 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I've seen alot of guys tighten the lash up on the 590 cam with good results but it never helped mine, it liked 28/32 in my 451 with Eddy heads and it was a 9 second bracket car. Maybe it just didn't like the extra lift since it was a mild combo with low compression.
