Re: Cal Trac with super stock springs
[Re: Cab_Burge]
#2299563
05/05/17 02:46 PM
05/05/17 02:46 PM
Posts: 3,060 Western New York
sixpackbee
Western New York
They need to used with the mono leaf they are designed for if you want to get the most out of them. If you are running an E or B body with a longer front segment that systems works well. A bodies with a good SS spring suspension, front and rear sorted out, work just as well. My Duster stocker has gone 1.36 60' with SS springs.
1959 Bugeye Sprite 1967 Charger Black L code 1967 Coronet R/T Convert Green 440 auto bought from original owner 1968 Charger R/T Bronze 440 4 spd console AM/FM 1969 Super Bee WM21H B5 A40 D21 N96 1969 Barracuda Formula S 340 Convert pilot car 1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85 1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96 1970 Road Runner RM21N B3 V1X D13 1971 MG Midget 1971 Road Runner RM23H GW3, A57 1972 Road Runner RM23P FY1, D21
[Re: sixpackbee]
#2299700
05/05/17 08:01 PM
05/05/17 08:01 PM
Posts: 4,672 Wichita
GY3
Wichita
They need to used with the mono leaf they are designed for if you want to get the most out of them. If you are running an E or B body with a longer front segment that systems works well. A bodies with a good SS spring suspension, front and rear sorted out, work just as well. My Duster stocker has gone 1.36 60' with SS springs. SS springs and Cal-tracs do NOT play well together! I tried it last Fall and it porpoised BADLY! I clamped the front and rear segments together as a stop gap solution and it calmed down but they really need split mono springs with the Cal-Trac bars. I used the 3400 lbs. SS springs in my 3400 lbs. car and they worked well for about half a season. The made in Mexico springs tend to lose their arch, flatten out and wrap up on launch. I need to get to the track with the whole setup but up to this point it's rained every weekend!
[Re: GY3]
#2299706
05/05/17 08:12 PM
05/05/17 08:12 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I am by no means as savvy as a lot of you on here however I find the Caltracs quite easy to set up with both springs being equal. Biased springs would be a real hassle to tune them for IMHO.
Sheldon
[Re: rtpete]
#2299827
05/05/17 11:43 PM
05/05/17 11:43 PM
Posts: 8,869 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Isn't the bar on the bottom there to prevent wind up? Spring is just to hold the car up, Exactly, and the front leaf acts like the top link in a 4-link or the top bar in a ladder bar. Not to say the CalTrac wouldn't work with a S/S spring but the spring front segment is designed to have very little wrap-up. With the CalTrac system, its the wrap-up of the front segment that slaps the bar up and plants the tire. With the S/S springs you'd have to adjust the bar to have very little movement because there's no wrap-up and subsequently no "shock" - therefore virtually none of the affect they're designed for.
[Re: rtpete]
#2301170
05/08/17 02:21 PM
05/08/17 02:21 PM
Posts: 1,550 Michigan
Kiddart
Race Craft makes a suspension aid. its called, assain Bars. I have read and heard they do work and are effective on Mopars with Super stock springs. they need some adjusting and such but what doesn't. they have a lot of holes for different adjustments. they guys I see run them are quick in 60 foots.
Just my two cents
Thank you Kiddart
[Re: Kiddart]
#2301253
05/08/17 05:01 PM
05/08/17 05:01 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
Just my two cents I was looking at the Assassin Bars. I am using front spring hangers to lower my car. If I install Calvert's the bottom of the spring hanger will have to be trimmed to make clearance for the front bracket on Calvert bar. With the Assassin's I don't think there will be any interference.
1974 Roadrunner
1967 Charger
[Re: Saskabusa]
#2301328
05/08/17 08:10 PM
05/08/17 08:10 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You guys are not understanding that any of these bars.. they all add more lift to the chassis... any time you ad more lift(separation) you need stronger shocks to control the separation
[Re: MR_P_BODY]
#2301347
05/08/17 08:53 PM
05/08/17 08:53 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
You guys are not understanding that any of these bars.. they all add more lift to the chassis... any time you ad more lift(separation) you need stronger shocks to control the separation You are correct mike!!!!With both you would never get enough shock control
JAKES AUTOMOTIVE
[Re: rtpete]
#2301399
05/08/17 10:36 PM
05/08/17 10:36 PM
Kiddart
I understand the issue Mike. controlling separation is the key and good shocks help out a bunch with that.
Thank you Kiddart
[Re: rtpete]
#2301451
05/08/17 11:32 PM
05/08/17 11:32 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I am using front spring hangers to lower my car. If I install Calvert's the bottom of the spring hanger will have to be trimmed to make clearance for the front bracket on Calvert bar. Should not be an issue, go to the CalTracs site and look at the front bracket and how it works. What you do need to worry about is that the hanger is wide enough to take the Caltrac bracket!
[Re: Clanton]
#2301946
05/09/17 07:50 PM
05/09/17 07:50 PM
Posts: 610 long time lurker, short time p...
PorkyPig
I have been using the Cal trac with ss for a while but I have not got the tune correct for a number of reasons and use QA-1 shocks so you are not the only 1 to try it.I am stuck with it so I will keep at it. I only knew of one person who got CalTracs to work the SS springs, and even he admitted it wasn't a great choice. I'm pretty sure he doesn't use those springs any longer, but I haven't seen his car up close in years.
[Re: Stanton]
#2302009
05/09/17 09:58 PM
05/09/17 09:58 PM
Saskabusa
Scatchamatoon
I am using front spring hangers to lower my car. If I install Calvert's the bottom of the spring hanger will have to be trimmed to make clearance for the front bracket on Calvert bar. Should not be an issue, go to the CalTracs site and look at the front bracket and how it works. What you do need to worry about is that the hanger is wide enough to take the Caltrac bracket! I installed a set on my brothers 68 Charger and ran into this issue. He had bought AR engineering spring hangers from Mancinni. When the spring eye was in the upper hole the calvert bracket hit the spring hanger. We used the factory bracket instead.
1974 Roadrunner
1967 Charger
