Re: Bottom of car Paint..
[Re: Wolfe440]
#2298230
05/03/17 12:20 PM
05/03/17 12:20 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
They were dipped in primer. Resto Rick sells the paint you want to get the factory look, then body color oversprayed on to the dip primer colored paint. I like to use epoxy then resto rick primer look paint on top of that.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2298243
05/03/17 12:47 PM
05/03/17 12:47 PM
Posts: 217 New Port Richey, Florida
Wolfe440
They were dipped in primer. Resto Rick sells the paint you want to get the factory look, then body color oversprayed on to the dip primer colored paint. I like to use epoxy then resto rick primer look paint on top of that. Ok, great, that will do it! Thank You!
[Re: Wolfe440]
#2298363
05/03/17 04:12 PM
05/03/17 04:12 PM
Posts: 21,219 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
The primer bath color can be found behind your door panels and about half way up the firewall on the interior side.
My car (70 Dart) had a medium charcoal grey color dip line, and not the lighter gray that I see in car magazines and internet photos. Maybe it's the camera flash that makes the grey look lighter I don't know. Maybe each plant had a slightly different mixture of whatever they used and it changed as they replenished it over time?
[Re: Neil]
#2298559
05/03/17 11:04 PM
05/03/17 11:04 PM
Posts: 714 California
BigDaddy440
California
I have no idea how close this is to a factory look, but this is what I did after reading about what the underside of a factory fresh car looked like. My body guy, then sprayed a very low gloss clear over the primer on the underside to help seal it.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
[Re: BigDaddy440]
#2299034
05/04/17 05:50 PM
05/04/17 05:50 PM
Posts: 27,552 So Cal
autoxcuda
So Cal
I have no idea how close this is to a factory look, but this is what I did after reading about what the underside of a factory fresh car looked like. My body guy, then sprayed a very low gloss clear over the primer on the underside to help seal it. Looking good! Hope to see it in person at a spring fling
