Re: 1/2 turn hidraulic lifter preload
[Re: Stanton]
#2297679
05/02/17 12:06 PM
05/02/17 12:06 PM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
Is this a big block or small block ??
It is a big block,a 440. I had too much play between a couple of rockers so i removed the saft to put more shims. That is why i had to redoing the preload and it,s when i noticed that two of the lifters were "solids"
[Re: 540DUSTER]
#2297680
05/02/17 12:13 PM
05/02/17 12:13 PM
Coke
Vitoria, Spain
install lifters dry,adjust valves,then pre-lube engine.If your valves are close to the piston,don't try to adjust with oil in the lifter.I don't know how primeing lifters with oil before adjustment became the standard,but it is wrong!I think it is a chevy thing. There was not too much interference risk in this engine if i recall correctly. The pushrods are ok.i will have to check if have bent a valve... Just in case..
[Re: Coke]
#2298156
05/03/17 09:32 AM
05/03/17 09:32 AM
Coke
Vitoria, Spain
I have been reading the entire post again and i,m noticing tha maybe there is an undermistaken. My fault for sure . I think that have not been able to express the case correctly.
I have not mentioned that the engine has been running with this cam and lifters previously. I rebuild the engine on a stand,adjusted the preload,prelubed it and installed on car. Then i did the cam break in.
I started to do the valve adjustment again because i removed the rocker shafts to correct the clearance between rockers because i did not a good job on this while engine was in the stand.That is when i found the issue with the two lifters.
I did want to clarify this because you are suggesting me to prelube the engine and maybe i confused you and you are thinking that i still haven,t started the engine.
Right now i don,t know if it is usual to prelube lifters wich has been alreay working on a running engine or if you need to do this every time you loss the preload,like this case that i have removed the shafts after running the engine. I,m a little confused about this.
I apologize for the inconveniences Thanks
[Re: 540DUSTER]
#2298236
05/03/17 12:38 PM
05/03/17 12:38 PM
Coke
Vitoria, Spain
Coke,if you have some lifters that won't bleed down even when you put pressure on them and the valves are opening when you try to adjust,you might have to pull the lifters and take them apart to drain oil out.Make sure they are clean.
Just one example, If i remove the valve caps on an engine wich has been running,say the day before, How should be the lifters wich are in the cam base circles(closed valve)? Should i be able to move the rocker back and forth? If i grab the pushrod between my fingers, should i be able to press the plunger down and feel it spongy? Thanks
[Re: buildanother]
#2298250
05/03/17 12:55 PM
05/03/17 12:55 PM
RapidRobert
I do my preload checking setting/adjusting before I preoil as I am just getting the up & down play of the pushrod to zero with the lifter spring pushing the cup up against the clip then adding in however much preload I am after by extending the pushrod length/turning the adj rocker screw. this is for preliminary setup and after running. if it is better to do it while pumped up then I am willing to change to that.
[Re: Coke]
#2298259
05/03/17 01:14 PM
05/03/17 01:14 PM
Posts: 8,924 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Should i be able to move the rocker back and forth? Absolutely not. The lifter should never bleed more than the amount of pressure placed on it. i.e. all pressurized lifters sitting in the motor with no pressure on them (no pushrods installed) should not bleed down AT ALL. Why? Because there is nothing to push the oil out. Keep this in mind ... depending on RPM you have anywhere from 20 to maybe 70 pounds of oil pressure to pressurize the lifter. You have more than 300 pounds of spring pressure trying to force the oil out of the lifter. Therefore the lifter has to be designed NOT to bleed off that oil easily otherwise you'd never reach the potential of the cam.
[Re: Stanton]
#2298537
05/03/17 10:25 PM
05/03/17 10:25 PM
RapidRobert
I'd still take those two apart & clean em/reinstall & see if that takes care of it. it'd be nice as no breakin will be needed which would be if you get (2) new lifters.
[Re: Coke]
#2298572
05/03/17 11:29 PM
05/03/17 11:29 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I'd still take those two apart & clean em/reinstall & see if that takes care of it. it'd be nice as no breakin will be needed which would be if you get (2) new lifters. Means taking the intake off. If you're that concerned I'd put those two at max lift overnight and check the next day to see if they bleed down.
[Re: RapidRobert]
#2298584
05/03/17 11:40 PM
05/03/17 11:40 PM
Posts: 4,324 Prospect, PA
BSB67
Prospect, PA
I'd still take those two apart & clean em/reinstall & see if that takes care of it. it'd be nice as no breakin will be needed which would be if you get (2) new lifters. Those are the only two that are good. The other 14 are junk, IMO. Everyone has just gotten so use to it... it is just the new norm.
[Re: Stanton]
#2298655
05/04/17 01:31 AM
05/04/17 01:31 AM
Coke
Vitoria, Spain
I was thinking on that idea too . I don,t want to think that a set of lifters wich has been running less than an hour in total are already junk. We are going to start for the easiest thing, wich is preoling to see if they get pressure and set the valve adjustment again. If not i will remove the intake to see what is happening here. How much i should to loose the rockers adjusters? Just enough to evit tha the pushrod escapes from the adjuster ball ? If loose them all the way off the cups are going to damage the rockers while i,m turning the crankshaft.
