Deep oil pan oil control #2296118
04/29/17 02:53 PM
04/29/17 02:53 PM
Great Neck,LI,new york
hemi-itis Offline OP
I was given an aluminum fabricated oil pan.It has a large deep sump with a 2 or 3 inch shelf about 3 inches from the bottom of the pan and extending about 2 inches out.I will be using a swinging pick up and was curious if there is anything I should be doing to this pan for oil control.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Deep oil pan oil control [Re: hemi-itis] #2296129
04/29/17 03:23 PM
04/29/17 03:23 PM
A727Tflite Offline
A727Tflite  Offline
Looks like an early Charlie's pan. If no internal swinging trap door you need to keep a lot of oil in it. A scrapper is a good idea too. See how much liquid it takes to fill it to the bottom of those accel/decel shelfs. You need that as a minimum plus 4 quarts.
Re: Deep oil pan oil control [Re: hemi-itis] #2296274
04/29/17 10:47 PM
04/29/17 10:47 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
My Milodon pan has a built in windage tray, plus I have a scraper in it. I had problems at the beginning of my racing with the old 8 quart center sump pans. When I hit the brakes at the traps, I would lose oil pressure. As soon as I put a windage tray in it, that problem went away. I always use a windage tray as minimum now, but I really like the crankscraper setup as a back up.
[image][/image]
Re: Deep oil pan oil control [Re: hemi-itis] #2296277
04/29/17 10:52 PM
04/29/17 10:52 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That pan needs a trap door
Who welded the heads? Was that for porting?
Re: Deep oil pan oil control [Re: hemi-itis] #2296349
04/30/17 01:42 AM
04/30/17 01:42 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
have any extra dual plug heads hemi-itis
Re: Deep oil pan oil control [Re: hemi-itis] #2296429
04/30/17 11:24 AM
04/30/17 11:24 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine has the shelf in the rear, swinging pick up and a trap door. Trap door attaches at the bottom rear of the tie rod tube. I run the level at the top of the tie rod tube. The pan has been run as low as 6 qts (actual level in the pan). Normally 7 qts in the pan. Attatched is the diagram sent to make the diaper.
Doug
Re: Deep oil pan oil control [Re: hemi-itis] #2296447
04/30/17 11:59 AM
04/30/17 11:59 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Looks like a 440 Source copy of the Charlie's pan to me Big Al.
No trap door and IMO it needs one with that long bottom sump.
I have a Charlie's from the early 90's with the trap door and custom made a windage screen out of a old windage tray.
No pics as someone in Russia thought it would be funny to hold my computer ransom and I lost ALL my chit flame
Re: Deep oil pan oil control [Re: dvw] #2296470
04/30/17 12:53 PM
04/30/17 12:53 PM
tboomer Online work
tboomer  Online Work
Excellent sketch,Doug!! Just what I have been looking for!! wave
Re: Deep oil pan oil control [Re: FastmOp] #2296476
04/30/17 01:05 PM
04/30/17 01:05 PM
Steve Sanchez@ Total Flow did these heads for Koeffel in the early 80's.
They were done for a fueler car.
Heads were done by Steve Sanchez @ Total Flow Products in the 80's.They have been sitting in a cabinet in the garage for 25 ish years
Re: Deep oil pan oil control [Re: dart games] #2296477
04/30/17 01:07 PM
04/30/17 01:07 PM
Sorry,I'm blessed to have these and finally be able to use them.I'm confident the car will pick up some eek
Re: Deep oil pan oil control [Re: roadhazard] #2296481
04/30/17 01:14 PM
04/30/17 01:14 PM
DING<DING<DING,,,,,we have a winner! Your right Greg,after the actual owner came out of a coma I was able to find out they were made by 440 Source.When I 1st spoke with Scott,who is great friends with the gent that had to give up his 64,,his Hemi,,and many misc parts he wasn't sure who made them.He gave me the pan and would move the centerlink tube if need be.Here is the mock up,,,,,PERFECT!!!
Re: Deep oil pan oil control [Re: dvw] #2296489
04/30/17 01:21 PM
04/30/17 01:21 PM
Doug
As always Doug is right there with the info I need.I followed your lead on the "K" and steering plate.Now the oil pan bow
How does the trap door work with a swinging pick up??I had a real nice scraper when I sent the engine out last time to freshen.When we opened it up after 5 years,there was NO scraper.Is it possible to fab something IN the pan so I don't have to have double gaskets on the pan??
Re: Deep oil pan oil control [Re: hemi-itis] #2296496
04/30/17 01:31 PM
04/30/17 01:31 PM
The block is coming out in the next few days.Then I can measure some different oil levels and figure out how much oil I need to carry in the pan and fab some oil control.
The header tubes need to be welded and the "k" boxed.I have an old school steering box support.You guys ever see one of these?
Re: Deep oil pan oil control [Re: hemi-itis] #2296512
04/30/17 01:58 PM
04/30/17 01:58 PM
A727Tflite Offline
A727Tflite  Offline
What's the part number cast in to your heads?
Re: Deep oil pan oil control [Re: hemi-itis] #2296587
04/30/17 03:47 PM
04/30/17 03:47 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Hemi-itis nice steering box brace. Is that made anymore and by who? If not you should trace that out so you can make a second one if you need it.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Deep oil pan oil control [Re: hemi-itis] #2296599
04/30/17 04:27 PM
04/30/17 04:27 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I made an aluminum box piece that just slid under the steering tube ,not really a box as it only has 2 ends. one that fits up against the back of the pan and the other in front of the tube. It is as wide as the pan. It has a slice bent into it to allow oil to flow in during acceleration but restrict the flow coming out .It also keeps the oil from slamming up in to the crank on launch, at least the oil that is below the tube level.
Re: Deep oil pan oil control [Re: hemi-itis] #2296604
04/30/17 04:37 PM
04/30/17 04:37 PM
warren, mich.
dwayne welder Offline
warren, mich.
I worked with Steve Sanchez back in 1974 at Diamond Racing, I still stay in touch with Steve now and then.
Re: Deep oil pan oil control [Re: A727Tflite] #2296793
04/30/17 09:55 PM
04/30/17 09:55 PM
p4120960
Re: Deep oil pan oil control [Re: hemi-itis] #2296869
04/30/17 11:28 PM
04/30/17 11:28 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How does the trap door work with a swinging pick up??I had a real nice scraper when I sent the engine out last time to freshen.When we opened it up after 5 years,there was NO scraper.Is it possible to fab something IN the pan so I don't have to have double gaskets on the pan?? [/quote]
Mine has a mesh screen that bolts into the pan. It is a Charlies pan.
Doug
Re: Deep oil pan oil control [Re: hemi-itis] #2296931
05/01/17 01:01 AM
05/01/17 01:01 AM
I have been searching for pictures of baffles or trap doors.All the fabricators say it's there, but with no pictures. runaway
