Cuda steering column help!
#229548
02/19/09 08:55 AM
02/19/09 08:55 AM
Posts: 511 South Georgia
tx9cuda
South Georgia
Any tips on how to re-install the heavy signal cancelling spring on the rear of the steering wheel can?? Looks like tough task to spread it. thanks
1971 BS23H1B
Re: Cuda steering column help!
[Re: tx9cuda]
#229549
02/19/09 10:38 AM
02/19/09 10:38 AM
Challenger 1
Cincinnati, Ohio
gOT ANY PICTURES?
[Re: Snoopy]
#229557
02/22/09 12:17 PM
02/22/09 12:17 PM
tx9cuda
South Georgia
Just to update- I did recoat the horn ring, the original coating had crumbled off. I also got the coil installed. The end of the shaft on the crush can is beveled to help start the coil. The key is to get the coil started evenly (square)using a flat surface across the coil. Then I actually used a fork that just luckily fit across the circumference of the coil-made contact 2 places 180 degrees apart. It tapped in to place easily then. You cannot use a round socket because the tang that trips the signal switch is in the way. If you had to do this a lot you would need to make a special tool for this job. thanks again
1971 BS23H1B
[Re: cuda-sweden]
#229561
08/21/09 12:41 PM
08/21/09 12:41 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
anyway is that horn ring 3488981 posted in the picture by snoopy the right one for a 70 cuda?
It is not the correct one for a 70 Cuda, but it could be used if you extended the wire 3 1/2" (8.89 cm) and used shrink sleeve at the ring end where the wire passes through the crush can. The correct wire length is 10" (25.4 cm). The correct part number is 2947874.
