Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#2296608
04/30/17 04:48 PM
04/30/17 04:48 PM
Posts: 1,893 Spahn Ranch
RMCHRGR
Spahn Ranch
This is truly looking out to be a scale wars type of thread started by no other than RMCHGR himself.
I tossed that scale in the trash when I got home the other night.
'71 Duster '72 Challenger '17 Ram 1500
[Re: OUTLAWD]
#2296667
04/30/17 06:44 PM
04/30/17 06:44 PM
Posts: 608 TN
1DGEMAN
TN
Back to the headlight topic... A few years ago I swapped to a plastic H4 conversion headlight I picked up for $35/pair off amazon. I have since swapped to LED's for the low current draw and awesome light output, but was digging in the basement and came across the old ones, so I threw one on my scale. 8 oz with the bulb and rubber boot https://www.amazon.com/gp/product/B001UG9K04/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1looks like they went up in price Thanks for the info. I was unable to find if they made the smaller headlight for a Challenger. This would be good weight savings for the race car.
Real Men shift for themselves
[Re: Thumperdart]
#2296677
04/30/17 07:02 PM
04/30/17 07:02 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
New show,,,Tales of the scales!!! https://www.amazon.com/Tale-Scale-Odyssey-Invention/dp/019984982XAs told by Solly,,,,,,,,,Might be an alias of haze the author,,,,,,,, https://en.wikipedia.org/wiki/Weighing_scale
#2296767
04/30/17 09:23 PM
04/30/17 09:23 PM
hemi-itis
I am full SCALE ahead Machine shop offered to lighten the block by up to 50 lbs,but I don't need a 4.5 bore,,,,,,,,,yet!
[Re: Thumperdart]
#2296844
04/30/17 11:02 PM
04/30/17 11:02 PM
hemi-itis
I can not comment on the grounds and positives of this matter I ain't got no names to name
[Re: Thumperdart]
#2296933
05/01/17 01:14 AM
05/01/17 01:14 AM
Posts: 200 Colorado
Bob J
Colorado
When you showed I look at again and seen the I didn't level the scale. The new weight is 8 lbs 7 oz. Here a another pic of the scale. And yes I also have a wood shop and that is where the drill press is at so the scale is there to see hoe much weight I'm removing.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
#2296969
05/01/17 05:45 AM
05/01/17 05:45 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Oh Sheeet. Never mind that starter, what's up with that super Kool scale????
Mine is made in Mississippi and with good craftsmanship. Come on guys, break out your best scales and show 'em on the glass. I've got one in reserve for the last close to chest card move. LOL. You know... i was just going to post about scales... seeing as you guys are getting down to a 1lb difference in starters. Just thought i should mention that using a bathroom scale is NOT an accurate way to weigh non-human-sized items and beings. It just doesn't work, and can easily make or break your 1lb obsessions. I use a calibrated dairy scale, goes to 60lbs, and you hang it, and it has a hook on it. Even then were are splitting hairs past 0.1lbs, but its enough for what i need. I've seen people (at gyms) weigh plates and such on gym scales (like in Hemi-itis' post) for years, and they can be as far as 5lbs off a 45lb item, while being relatively accurate when a person uses it. Dont use people scales.
[Re: hemi-itis]
#2296970
05/01/17 05:48 AM
05/01/17 05:48 AM
Pale_Roader
Swears too much
Swears too much
How much weight can I save if i go from 20-50 to 10-3o?? Just do what i did and keep it under 2 liters. Yeah... might get a bit hot, but if you build a loud enough exhaust you wont hear any ov the engine drama... Did you know you can actually run a 440 on 1.5 liters ov oil? Did you also know that a 440 will still run at 400 degrees? Kudos to the factory engineers. Carry on.
