230 flathead...oil filter location ?? #2294886
04/27/17 08:40 AM
04/27/17 08:40 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
I have a 56 dodge p/u with a 230 flathead six...can't locate the oil filter ? Any help appreciated...Thanks Moparts..Thanks to all in advance
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2294897
04/27/17 08:59 AM
04/27/17 08:59 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Black canister to right of distributor/coil and above starter is the oil filter housing.
Don't be the exception.
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2294926
04/27/17 09:57 AM
04/27/17 09:57 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
Nice flathead. Mine's a bit of a mess.
Re: 230 flathead...oil filter location ?? [Re: 71charger] #2294951
04/27/17 10:55 AM
04/27/17 10:55 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
see pic above..mine appears ommitted
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2294952
04/27/17 10:57 AM
04/27/17 10:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Many did not have a filter.had a 55 that did not have one.IIRC back then dealers installed a lot of them.My 47 didnt have one either.rocky
Chrysler Firepower
Re: 230 flathead...oil filter location ?? [Re: therocks] #2294993
04/27/17 12:36 PM
04/27/17 12:36 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Thanks...anyone have a source for an entire assembly ??
Thanks in advance
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2295029
04/27/17 01:30 PM
04/27/17 01:30 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Entire kit? Not sure, I know www.oldmoparts.com has the canister and filters, but the plumbing you'd have to ask them. I don't think I have ever owned a Mopar flathead that didn't have the oil filter installed.
Re: 230 flathead...oil filter location ?? [Re: Supercuda] #2295043
04/27/17 02:01 PM
04/27/17 02:01 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2295049
04/27/17 02:12 PM
04/27/17 02:12 PM
dogdays Offline
dogdays  Offline
They weren't always standard equipment, although I'd think by '56 it would have been.
Also possible they were optional and dealer ordered vehicles without them and then sold an aftermarket kit which he installed.
Here's an original. My family was strictly GM so my memory is of the housing with a big AC sticker on it.
http://www.ebay.com/itm/Antique-car-truck-AC-style-oil-filter-assembly-1930s-1950s-/162353234465?hash=item25cd01c221:g:EboAAOSw9GhYdNpO&vxp=mtr
As an alternative there were the "beehive" filters added by hot rodders for visual pop.
http://www.ebay.com/sch/i.html?_odkw=bee...r+&_sacat=0
Keep in mind that these oil filters were not full flow filters. As the engines had been designed in the 30s, when oil filters were definitely optional, the first oil filters bled off oil from near the oil pump and after filtering drained it back into the sump. That's why you see so many of these filters with a small copper tube running to the block.
PureOLator was the first. My 1928 Allis Chalmers was the first farm tractor to come standard with an oil filter. But many many tractors had canister filters into the '60s. So don't discount tractors and tractor stores as sources.
There are also the remote filter assemblies sold by all the hot rod shops. You'll just need to get a little creative with the plumbing.
R.
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2295054
04/27/17 02:19 PM
04/27/17 02:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: 230 flathead...oil filter location ?? [Re: Supercuda] #2295135
04/27/17 03:56 PM
04/27/17 03:56 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Originally Posted By Supercuda
Excellent stuff...Thanks
Re: 230 flathead...oil filter location ?? [Re: dogdays] #2295136
04/27/17 03:57 PM
04/27/17 03:57 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
R.
Thanks...excellent
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2295273
04/27/17 08:36 PM
04/27/17 08:36 PM
IN
ahy Offline
ahy  Offline
IN
Looks like vintage power wagons (VPW) has them. Tubing is regular steel auto tubing (like fuel line) and flared. ACE hardware (a good one) probably has the fittings you would need.
As mentioned, it is a bypass style filter... it only filters part of the oil flow. Oil to the bearings comes right from the sump.
https://drive.google.com/file/d/0BxzO_Oy1EMLIWVFzSHRzNjlOMWs/view
Re: 230 flathead...oil filter location ?? [Re: ahy] #2295293
04/27/17 08:59 PM
04/27/17 08:59 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
thanks also...excellent stuff
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2295339
04/27/17 10:15 PM
04/27/17 10:15 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've got one of those filter canisters here if your interested. I have no idea what its worth. If your interested, PM me here. Gene
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2295581
04/28/17 11:30 AM
04/28/17 11:30 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
THANKS to all. Thanks Moparts....I found on e-bay the canister...mounting bracket with canister holde and two new filter elements for 43.00 delivered. All's I need to do is work the plumbing. Thanks again...Tom
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2295592
04/28/17 11:55 AM
04/28/17 11:55 AM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
You got a good deal. The filter elements have gotten expensive. The last ones I bought were Fram that were made in Turkey. Probably a holdover from all the Fargo trucks that were made and marketed there.
Re: 230 flathead...oil filter location ?? [Re: 71charger] #2295638
04/28/17 01:43 PM
04/28/17 01:43 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
2 wix elements
Re: 230 flathead...oil filter location ?? [Re: terzmo] #2297208
05/01/17 02:49 PM
05/01/17 02:49 PM
dogdays Offline
dogdays  Offline
To finish the discussion...The majority of stuff that the oil filter removes is dust which gets into the engine. If you run an air cleaner the oil filter has very little to do. Sure, it traps larger particles from failing engine parts, but when that happens the engine needs to be rebuilt anyway.
I guess this is my way of telling the OP that he need not change the filter element every time he changes the oil.
And keep the farm stores in mind for replacement cartridges.
R.
Re: 230 flathead...oil filter location ?? [Re: dogdays] #2300391
05/06/17 10:22 PM
05/06/17 10:22 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
The logbook I received with the truck shows the owner had it from 1979 through 2017. He put 9000 miles on it during that time and changed the oil every 500 miles. Included were receipts and entries of other parts replaced and repairs. Interesting stuff
