Re: 727 noisy wining wont drive [Re: Petri.] #2298388
05/03/17 04:52 PM
05/03/17 04:52 PM
Sweden
P
Petri. Offline OP
Petri.  Offline OP
P
Sweden
Measured the end gap on the smaller shaft towards the bigger shaft that i cant move out and in,gap is 1.6mm and measured several times with a digital caliper.
Re: 727 noisy wining wont drive [Re: Petri.] #2298550
05/03/17 10:54 PM
05/03/17 10:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
yep.... awaiting to see what the OP finds.
Re: 727 noisy wining wont drive [Re: Petri.] #2299622
05/05/17 05:12 PM
05/05/17 05:12 PM
Sweden
P
Petri. Offline OP
Petri.  Offline OP
P
Sweden
Crap
Re: 727 noisy wining wont drive [Re: Petri.] #2299628
05/05/17 05:26 PM
05/05/17 05:26 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
sprag is kaput. Looks like a crack in the case?
Don't be the exception.
Re: 727 noisy wining wont drive [Re: Supercuda] #2299638
05/05/17 05:39 PM
05/05/17 05:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yep, case is kaput too, the ring that surrounds the sprag has broken away, fairly common failure.
Re: 727 noisy wining wont drive [Re: Petri.] #2314028
05/31/17 02:55 AM
05/31/17 02:55 AM
Sweden
P
Petri. Offline OP
Petri.  Offline OP
P
Sweden
Hi again , now it has a rebuilt tranny in it and manual valve body but when sitting for a day it drains the converter back to the pan, what causes this.
Also i bought a coan converter thas has been sitting in a mild 440 and stalled 2800rpm, i have problems when i want to drive slowly, its twitching and jumping before i get som rpm and the engine can also stopp before i get rpm , i did not have these problems before but it has always been a little annoying when cruising but i know it gets to much fuel at iddle so that i have to fix,ignition is at 36 degrees and 10 at idle, this is the setup from previous owner.
Block Hi-Nickel Content (not original block)
Bore .030 over
Mopar steel rods
Keith Black 9.0 to 1 comp pistons
Moly rings
Clevite 77 main & rod bearings
Forged steel crank shaft
Complete balanced assembly
Cylinder heads (906) large valves with hard seats
Valve job with comp springs
Comp hyd cam 272 degree x 480" of lift
Cloyes dbl roller chain & gears
Melling high volume oil pump
Intake manifold is a HP 383 with Carter afb 625
Pertronics electronic ignition with MSD coil (no points)
Exhaust is a 383-440 magnum HP manifolds
/Petri
