Re: what oil are you running in your street big block?
[Re: Nick Mineau]
#229322
02/19/09 12:48 AM
02/19/09 12:48 AM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
MY current ride isnt running yet, but I have always run SAE30.
[Re: Nick Mineau]
#229324
02/19/09 01:04 AM
02/19/09 01:04 AM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
Valvoline 10W30 60 psi at idle, 80 psi at 3000
doesnt usually get below freezing here but its been an unusually cold winter so Ive been careful not to start it below 30 or so
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: Coronet-R/T-Rag]
#229325
02/19/09 09:27 AM
02/19/09 09:27 AM
Posts: 190 Wilmington,NC
I go fast
Wilmington,NC
I run Shell 15w-40 Rotella diesel oil. You need the Zinc for your cam. Most passenger car oil had the zinc reduced to a potentially dangerous level.
And the current Rotella has reduced zinc levels to a point much less than the original.It is no where near the old Rotella.Truck emission standards are being raised by the manufacturer and the oil is being blended to coincide,so don't take it for granted that you are home free.If you are set on diesel oil,Chevron Delo has more zinc than the Rotella.
[Re: I go fast]
#229329
02/19/09 10:29 PM
02/19/09 10:29 PM
Posts: 21,825 Kirkland, Washington
Pacnorthcuda
Raised "by the manufacturer" ??? Careful there. I work for a major heavy duty truck manufacturer. "WE" are not raising the emission standards. Not saying we don't support them--just clarifying.
[Re: Nick Mineau]
#229330
02/19/09 11:31 PM
02/19/09 11:31 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
I run regular 5W20 Valvoline(non synthetic)in my 518 C.I. stroker, it idles at 50 lbs at 900 rpm cold and 18 to 23 lbs at 900 rpm hot, above 170 F oil temp. I cut the oil pump bypass spring so the oil pressure never exceeds 70 no matter what rpm or oil tempertautre works good, last a long time, three years of drag racing (50 to 100 runs a year, 10:34 ET at 128.6 MPH in a 3400 lb Duster)and less than 1000 miles a year street driving
[Re: Cab_Burge]
#229331
02/20/09 06:20 AM
02/20/09 06:20 AM
Posts: 5,903 Athens, Greece
Pyper70
Athens, Greece
I run Castrol 20w50 in my 440. I hav 60lbs at 900rpm but thats also dependent on your HV Oil Pump & how tight your clearances are. I used to run straight 50w in my other 440 because the clearances were a bit looser....
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
#229332
02/20/09 06:34 AM
02/20/09 06:34 AM
Posts: 470 Big Chicago
amixon
Big Chicago
I go to farm and fleet and purchase two cases one for my Diesel and the other for the flat tappet hotrod! The valve train psi in a Diesel engine still require the missing zinc from automotive engine, but if you have a roller cam that changes things a bit
[Re: Pacnorthcuda]
#229334
02/20/09 09:26 AM
02/20/09 09:26 AM
I go fast
Wilmington,NC
Sorry,should have said being forced to raise standards.
[Re: hemi471]
#229337
02/20/09 02:13 PM
02/20/09 02:13 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
Valvoline VR-1 10W-30 untill break-in then Amsoil 10W-30 Racing oil.
Don't want to hi-jack but does the Amsoil syn have any ZDDP and also I've heard the synthetics are more prone to leaking (past gaskets) than Dino oil is.
