Thinking about going roller cam #2291734
04/21/17 07:13 PM
04/21/17 07:13 PM
sioux falls, sd
10sec.dart Offline OP
sioux falls, sd
Currently I'm running a flat tappet cam from hughes in my 360, 642 lift 290 duration, car runs really good as is with great cylinder pressure, but having to run the high zink oil and changing valve springs is getting a little old. would the price be worth it? would the bigger sprigs equal out the advantage of the roller lifters? I may just stay with the flat tappet, just seeing what everyone else thinks
Re: Thinking about going roller cam [Re: 10sec.dart] #2291929
04/22/17 01:58 AM
04/22/17 01:58 AM
What do you do with the motor? Drag race only, street only or both?
Is the 290 degree at .050 or is it the advertised duration?
