1970 RR buckets
#2291461
04/21/17 10:03 AM
04/21/17 10:03 AM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
I'm in need of '70 Roadrunner bucket seats. What years interchange if I get the correct covers new? Will E-body buckets be close? Thanks!
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
Re: 1970 RR buckets
[Re: chrisnben]
#2291485
04/21/17 11:38 AM
04/21/17 11:38 AM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
You can use 70 Plymouth B or E body seats. You will have to have the correct B body tracks. Otherwise the seats are pretty much the same. You could possibly use 70 Dodge seats as well. But I believe there are differences in the seat foam.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 1970 RR buckets
[Re: 70gtx440dana]
#2291493
04/21/17 11:48 AM
04/21/17 11:48 AM
Posts: 18,157 Mass
DAYCLONA
Mass
You can use 70 Plymouth B or E body seats. You will have to have the correct B body tracks. Otherwise the seats are pretty much the same. You could possibly use 70 Dodge seats as well. But I believe there are differences in the seat foam. Correct on all accounts, the seat tracks are 70 only, repros were available, don't know if still being made though? Mike
Re: 1970 RR buckets
[Re: Alaskan_TA]
#2291714
04/21/17 06:43 PM
04/21/17 06:43 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
1970 & early 1971 A, B & E body bucket seat frames are the same.
Yep, just need to change foam and upholstery
Re: 1970 RR buckets
[Re: DAYCLONA]
#2291895
04/22/17 01:10 AM
04/22/17 01:10 AM
Posts: 5,445 So Cal
Sinitro
So Cal
You can use 70 Plymouth B or E body seats. You will have to have the correct B body tracks. Otherwise the seats are pretty much the same. You could possibly use 70 Dodge seats as well. But I believe there are differences in the seat foam. Correct on all accounts, the seat tracks are 70 only, repros were available, don't know if still being made though? Mike PG Classic carries the repro tracks.. http://www.pgclassic.com/1840-st70lhNote they have a 25% discount for April 22/23 use the CODE: SAVE25... Just my $0.02..
Re: 1970 RR buckets
[Re: chrisnben]
#2294359
04/26/17 08:57 AM
04/26/17 08:57 AM
chrisnben
Madison, Wisconsin
thanks guys for the info!!
