Distributor lock collar...what's the point? #2291248
04/20/17 09:41 PM
04/20/17 09:41 PM
USA
JoesMopar Offline OP
USA
I'm using a lock collar on the MP distributor in my roller cam 440 because it was recommended. My question is...why? Why is this not needed when using a flat tappet cam?
Also, the 0.010" clearance between the collar and the top of the drive gear is almost impossible for me to set. When I use a 0.010" feeler gauge, I'm setting it lop sided because I can only slide it under one side of the collar. Also, IIRC the distributor shaft has some up and down play. Is that normal?
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2291268
04/20/17 10:11 PM
04/20/17 10:11 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I use one on my flat tappet. The purpose is to prevent the intermediate shaft oil pump drive gear from climbing up the vertical slop on the distributor shaft, which affects ignition timing due to the slant of the gear teeth. The lock essentially eliminates/reduces the amount of slop that the gear can climb.
Don't know why there might be a difference tween roller and flat cams.
My method of setting the collar is to install it with a bit of tension, LOW on the shaft, but not so much that it's locked to the shaft. Then install and bolt down the dist. Unbolt, remove dist, then lock down the collar in that position. Blue loctite on the set screw.
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2291273
04/20/17 10:16 PM
04/20/17 10:16 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Also alleged by some to lessen distributor shaft gear wear on the bronze gears typically used when running a roller cam.
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2291284
04/20/17 10:32 PM
04/20/17 10:32 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Use 2 feeler gauges one on each side.
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2291320
04/20/17 11:47 PM
04/20/17 11:47 PM
I would drive out the lower shaft roll pin & add some flat shims above the plastic collar to reduce the axial play to .005". speedway mtrs has an assortment of em in a kit for cheap, you want shims that are flat with no sharp edges like regular washers have on the ID/OD on one side which the ones in their kit are flat then reinstall the plastic collar then snug the lower metal add on collar in question on the shaft "snug" close to the bottom & install the intergear & the collar will be pushed up then remove the intergear & raise the collar up a hair from that position & tighten it & reinstall the intergear. when done twist the rotor back & forth lightly (not enough to get into the springs) & see how much rotational slop is left as that is what is to be eliminated. May need to weld or peen the lower tang for a better fit into the intergear notch if needed.
Re: Distributor lock collar...what's the point? [Re: RapidRobert] #2291509
04/21/17 12:17 PM
04/21/17 12:17 PM
USA
USA
Thanks again guys. I currently have it locked on the distributor but it's slightly lop sided. I'm guessing this thing isn't absolutely necessary unless you're racing?
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2291545
04/21/17 01:37 PM
04/21/17 01:37 PM
reduce the axial play to 5 thou & you might not even need it.
Re: Distributor lock collar...what's the point? [Re: Sxrxrnr] #2292096
04/22/17 02:04 PM
04/22/17 02:04 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Yes, it certainly would. That's a brilliant observation on someone's part.
Re: Distributor lock collar...what's the point? [Re: jbc426] #2292119
04/22/17 02:58 PM
04/22/17 02:58 PM
USA
USA
I'm using the coated gear instead of the bronze
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2292130
04/22/17 03:18 PM
04/22/17 03:18 PM
I've been told to slightly snug the collar onto the distributor shaft and then install the distributor into the motor and lock it down, rotate the motor over several revolutions and then remove the distributor and tighten the collar scope twocents thumbs
Re: Distributor lock collar...what's the point? [Re: Cab_Burge] #2292157
04/22/17 03:59 PM
04/22/17 03:59 PM
USA
USA
Thanks Cab
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2292408
04/22/17 11:30 PM
04/22/17 11:30 PM
I should have included to slide it down far enough on the distributor shaft so it has to hit the oil pump drive when tighten
down by the distributor hold down bracket blush realcrazy
Re: Distributor lock collar...what's the point? [Re: Cab_Burge] #2292467
04/23/17 12:41 AM
04/23/17 12:41 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Yep up
And don't do like I did the first time, didn't have it snug enough on the shaft and it slid off and sounded like a pin-ball machine going all the way down to the oil pan. shocked
Re: Distributor lock collar...what's the point? [Re: ProSport] #2308311
05/21/17 02:18 AM
05/21/17 02:18 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I would like to know where you buy the locking collar. Do you use a set screw type or the split or double split. Next thing , The distributor shaft is not the diameter of any that I found on line. Do you bore the collar out to the shaft size? or where do you purchase the correct size.
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2308394
05/21/17 11:18 AM
05/21/17 11:18 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
1/2" double split shaft collar works for me. A good hardware store or industrial supplier will have them. Graingers or McMaster carr for sure. Home Depot probably not.
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2308419
05/21/17 12:18 PM
05/21/17 12:18 PM
rowin4 Offline
rowin4  Offline
Thanks for your input GomangoCuda. Why I asked the question was that the collars I found on line were either 1/2" or smaller 7/16". The shaft on my distributor is smaller than 1/2" and a lot bigger than 7/16", Maybe the double split 1/2" collar might not be concentric around the shaft but apply enough clamping force to hold. It looks to be .010 - .012 under 1/2" Anyone else?
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2308484
05/21/17 01:49 PM
05/21/17 01:49 PM
AndyF Offline
AndyF  Offline
What is a distributor?
Re: Distributor lock collar...what's the point? [Re: JoesMopar] #2308597
05/21/17 05:05 PM
05/21/17 05:05 PM
rowin4 Offline
rowin4  Offline
Andy, my distributor hole plug looks similar to yours but doesn't have that black thing on top. By the way , whats in your water?
Re: Distributor lock collar...what's the point? [Re: rowin4] #2308908
05/22/17 02:52 AM
05/22/17 02:52 AM
this one clamps fine on a .4885 dist shaft. I don't remember if I got it at grainger or mcmaster/carr.
Re: Distributor lock collar...what's the point? [Re: RapidRobert] #2309240
05/22/17 06:32 PM
05/22/17 06:32 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Wow, You guys over complicate things. Here's what I've been doing since the 70's, all you need is a short piece of rubber hose 1/2" ID. Slip it over the shaft, tighten down the distributor, DONE. The hose will keep the intermediate shaft from dancing around and you'll have steady timing instead of a timing mark jumping around 5-7 degrees.
