Page 134 of 180 1 2 132 133 134 135 136 179 180
Re: Real world weight loss program and it` cost.......... [Re: dvw] #2290440
04/19/17 07:49 AM
04/19/17 07:49 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Originally Posted By dvw
Originally Posted By Pale_Roader
Have a quick question? Will removing the door beams compromise the integrity/structure ov the door any? Not talking impact here... just normal (gentle) usage. Dont want these suckers to sag or twist or do anything weird if i remove those beams.
Beams? we don't need no stinkin beams. Heck I cut the entire inner.
Doug
Heh... well mines gonna be a daily-driven street car. The windows roll down nice, they shut nice, and i'd like to keep it that way.
So what you're saying as that there is NO structure in the door?
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #2290455
04/19/17 09:21 AM
04/19/17 09:21 AM
fullmetaljacket Offline
The majority to a doors structural strength at least as far as the early B-bodies is the inner door panels themselves and two cross bridge gussets at the doors inner front hinge areas. I suspect that the other year and make doors are more or less the same except for the safety crash bar doors of 73' and up.
Now as DVW has done, his car is a one purpose car that sees little to none hard usage in opening/closing of doors and functional windows and such, so no worries there. His effort as a race car is the extreme of weightlessness (done beautifully) without adverse impact to that type of usage. Could it be used in such way on the street? maybe, but not without a concerted effort by the driver to be gentle with it and taking into account the grind of your teeth on the integrity of the door in a high usage environment as time goes on.
If you are using doors and windows as in a street car, I would keep the inner door metal panels in place, but gut them strategically so as to keep 'em strong and functioning and give a little teeny, puny, itty-bitty, petite, level of safety in a collision.
Just keep in mind that doors before the mid 70's were relatively light in structure. It is the inner workings of window rooster cranks, window glass,frames, lock mechanisms and even the crank handles/levers themselves that are heavy, not to mention the crash beams.
Crash beams are for just that, crashes. Do they take away from the doors ability to keep shape/form, no. unless of course, a crash like with any other door.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2290458
04/19/17 09:38 AM
04/19/17 09:38 AM
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Thats all i needed to hear. I can be nice, and i'm not worried about crashes (i drove a rusty Pinto for a year, and i'm driving a 2500lb Toyota right now.... I'm a gambler). As long as the things dont warp just driving/closing/operating windows i'm fine.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2290525
04/19/17 12:47 PM
04/19/17 12:47 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
FMJ,when you come out,,,,,,,,,bring your hole saw collection!!In the easter/passover spirit lets get HOLY!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2290536
04/19/17 01:19 PM
04/19/17 01:19 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
That's cheating!!! A Hemi and a blower...You don't need no stinking holesaws... biggrin
...FAFO...
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2290558
04/19/17 01:54 PM
04/19/17 01:54 PM
LOL.
The Holy water will boil when we step into the room. I feel like most cars need an exorcism of some sought.
I have every size of saws available.
talk soon.
Re: Real world weight loss program and it` cost.......... [Re: Pale_Roader] #2290560
04/19/17 01:57 PM
04/19/17 01:57 PM
Take your sweet time cutting at the beams. I've heard that they tend to come out in two parts. Also heard the spot welds are to be drilled out and the beams cut down the middle vertically with a small die grinder or cutting wheel.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2290618
04/19/17 04:18 PM
04/19/17 04:18 PM
an8sec70cuda Offline
What exactly is involved w/ removing the crash beam from a door? Can you get in there to cut it w/o butchering the door itself?
Do you cut it in 3 places....at each end to separate it from the door and the down the middle to make it easier to remove?
Or do you have to drill spot welds out? Then you're left w/ holes in the door?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2290621
04/19/17 04:26 PM
04/19/17 04:26 PM
TN
1DGEMAN Offline
1DGEMAN  Offline
TN
On my Challenger race car, I removed the glass drilled the spot welds out then cut the beam in the center with my plasma cutter. I slipped some sheet metal between the skin and beam before I cut. Worked fine.
On another note I have been looking for plastic headlamps for years and have never found any. The car has to have headlamps. Someone has to have a source.
Real Men shift for themselves
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2290635
04/19/17 05:09 PM
04/19/17 05:09 PM
hemi-itis Offline
hemi-itis  Offline
Is it possible to do the inside of the doors and retain the window regulator>>
Re: Real world weight loss program and it` cost.......... [Re: skicker] #2290636
04/19/17 05:11 PM
04/19/17 05:11 PM
hemi-itis Offline
hemi-itis  Offline
I have a little Jenny Craig wispering in my ear 32 hrs a day,,,,,,,,,,, whiney
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2290651
04/19/17 06:14 PM
04/19/17 06:14 PM
This thread is so large that people either have forgotten some of the picture posts or never got to catch up. I have gutted my inner door panels to the point where I removed about 4 Lbs from each door IIRC and the window regulators and lock mechanisms work just fine.
Some may not do it because of the amount of work and planning that goes with it, but every ounce counts as they say.
When I get a moment, I'll re-post my inner door pictures. The Lexan windows go up and down fairly well with a little guidance when they reach the top channels. This is of course, on a post sedan type of door.
Yes, I've heard that the beams in some cases had to come out in three parts and with care. Spot welds do need to be drilled out.
I removed the ones out of my Diplomat in two parts and it did not take out so much weight, but then again, Dippy doors are smaller than those mile long landscape Challenger and Charger doors.
Re: Real world weight loss program and it` cost.......... [Re: skicker] #2290731
04/19/17 09:47 PM
04/19/17 09:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
Yeah he does, up Full size Elephant are heavy whistling
N/A Wedge motors rule devil stirthepot boogie Hook and Book boogie grin
Re: Real world weight loss program and it` cost.......... [Re: Cab_Burge] #2290763
04/19/17 11:13 PM
04/19/17 11:13 PM
hemi-itis Offline
hemi-itis  Offline
Cab,you know cause you been there & done that bow
What's better than a boosted HEMI? tsk work runaway
And setting the block back a few inches,what's that worth? grin
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2290785
04/20/17 12:17 AM
04/20/17 12:17 AM
Here's a door again, though it was done somewhat crudely, once the interior dress panel was installed, it all disappeared.
This was the furthest extent that was capable of shaving some decent pounds, but still keep the door functional like stock.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2290839
04/20/17 03:08 AM
04/20/17 03:08 AM
My hat is off to all of you street racers that have done all that work to make the cars lighter bow up
My Duster weighed 3450 lbs. with me in it, I did not build it to be light realcrazy I never thought that car could or would run 10.00 on pump gas at that weight through the exhaust system on Oregon 91 octane pump swill boogie
The next one will be a lot lighter than the old one devil
the new "pump gas" motor will make a lot more power now that I know what a good set of heads will do to make more power whistling devil
Re: Real world weight loss program and it` cost.......... [Re: Cab_Burge] #2290882
04/20/17 09:27 AM
04/20/17 09:27 AM
Rather quite impressive to go that fast on pump corn and at that ballast back in the day. Combo's in the modern era are so much more obtainable and manageable with great heads on top of relatively small cubes like Cab mentioned
I personally built my rig to be light based on a few reasons.
First was the love for the factory hot rod effort back in the day which were turned too expensive for my wallet and sanity to own one of those gems. In the interim, what crawled into the project was the arts.
This project has turned a leaf in concept and process and has become a rolling sculpture of art to be exhibited in the future believe it or not. It's just a long process in the research, planning and development in order to reach that point.
Second was for reliability in a small package while it loiters out in the public.
What turned out was a fast package in an even lighter set up compared to the factory hot rods themselves and probably at the price point of insanity. LOL
What I can lay claim to is that it has been fun while it was incognito back in the day, but where it has been more fun is trading idea cards with y'all and only getting more funner and funnier as a civilian funny car.
The one thing that I can not lay claim to is that it moves its own weightlessness on pump since it's on a steady diet of Mo-jo.
Carry on guys, just don't carry the weight. LOL.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2290910
04/20/17 11:00 AM
04/20/17 11:00 AM
Howell, Michigan
Hemidavey Offline
Hemidavey  Offline
Howell, Michigan
Im building a 68 Dart with 426 and looking for any way to lighten it,reading everyones post is very interesting... I'll admit to going too far (timewise) but it was a challenge. I bought one of the Mopar crossram intakes and was surprised how heavy, just a click under 47 pounds. OUCH. So I looked it over and decided to put it on a diet, after many hours on the mill I pulled off over 7 pounds of aluminum. There are parts of that manifold that are over 3/4" thick, they dont need to be. I happened to have a mill so off I went whittling away. At first it was pretty straight forward, trim a little here and there then it got serious. I did this a few years ago and am looking for the photos of the aluminum pile that stacked up around the mill. lol
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2290943
04/20/17 11:53 AM
04/20/17 11:53 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I started using GreenLee knockouts instead of holesaws for most of my hole cutting...less chips and cleaner holes.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Real world weight loss program and it` cost.......... [Re: OUTLAWD] #2291087
04/20/17 04:50 PM
04/20/17 04:50 PM
I had to buy some of Greenlee Chassis punches for my pay Phone guy back when I supervised the pay phone guys many years ago.
Those punches are the cat meow up Not cheap though, but no good tools are shruggy
