Re: Real world weight loss program and it` cost..........
[Re: dvw]
#2290440
04/19/17 07:49 AM
04/19/17 07:49 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Have a quick question? Will removing the door beams compromise the integrity/structure ov the door any? Not talking impact here... just normal (gentle) usage. Dont want these suckers to sag or twist or do anything weird if i remove those beams.
Beams? we don't need no stinkin beams. Heck I cut the entire inner. Doug Heh... well mines gonna be a daily-driven street car. The windows roll down nice, they shut nice, and i'd like to keep it that way. So what you're saying as that there is NO structure in the door?
[Re: Pale_Roader]
#2290455
04/19/17 09:21 AM
04/19/17 09:21 AM
fullmetaljacket
The majority to a doors structural strength at least as far as the early B-bodies is the inner door panels themselves and two cross bridge gussets at the doors inner front hinge areas. I suspect that the other year and make doors are more or less the same except for the safety crash bar doors of 73' and up. Now as DVW has done, his car is a one purpose car that sees little to none hard usage in opening/closing of doors and functional windows and such, so no worries there. His effort as a race car is the extreme of weightlessness (done beautifully) without adverse impact to that type of usage. Could it be used in such way on the street? maybe, but not without a concerted effort by the driver to be gentle with it and taking into account the grind of your teeth on the integrity of the door in a high usage environment as time goes on. If you are using doors and windows as in a street car, I would keep the inner door metal panels in place, but gut them strategically so as to keep 'em strong and functioning and give a little teeny, puny, itty-bitty, petite, level of safety in a collision. Just keep in mind that doors before the mid 70's were relatively light in structure. It is the inner workings of window rooster cranks, window glass,frames, lock mechanisms and even the crank handles/levers themselves that are heavy, not to mention the crash beams. Crash beams are for just that, crashes. Do they take away from the doors ability to keep shape/form, no. unless of course, a crash like with any other door.
[Re: fullmetaljacket]
#2290458
04/19/17 09:38 AM
04/19/17 09:38 AM
Pale_Roader
Swears too much
Swears too much
The majority to a doors structural strength at least as far as the early B-bodies is the inner door panels themselves and two cross bridge gussets at the doors inner front hinge areas. I suspect that the other year and make doors are more or less the same except for the safety crash bar doors of 73' and up. Now as DVW has done, his car is a one purpose car that sees little to none hard usage in opening/closing of doors and functional windows and such, so no worries there. His effort as a race car is the extreme of weightlessness (done beautifully) without adverse impact to that type of usage. Could it be used in such way on the street? maybe, but not without a concerted effort by the driver to be gentle with it and taking into account the grind of your teeth on the integrity of the door in a high usage environment as time goes on. If you are using doors and windows as in a street car, I would keep the inner door metal panels in place, but gut them strategically so as to keep 'em strong and functioning and give a little teeny, puny, itty-bitty, petite, level of safety in a collision. Just keep in mind that doors before the mid 70's were relatively light in structure. It is the inner workings of window rooster cranks, window glass,frames, lock mechanisms and even the crank handles/levers themselves that are heavy, not to mention the crash beams. Crash beams are for just that, crashes. Do they take away from the doors ability to keep shape/form, no. unless of course, a crash like with any other door. Thats all i needed to hear. I can be nice, and i'm not worried about crashes (i drove a rusty Pinto for a year, and i'm driving a 2500lb Toyota right now.... I'm a gambler). As long as the things dont warp just driving/closing/operating windows i'm fine.
[Re: Thumperdart]
#2290525
04/19/17 12:47 PM
04/19/17 12:47 PM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
FMJ,when you come out,,,,,,,,,bring your hole saw collection!!In the easter/passover spirit lets get HOLY!
[Re: hemi-itis]
#2290536
04/19/17 01:19 PM
04/19/17 01:19 PM
Posts: 5,110 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
FMJ,when you come out,,,,,,,,,bring your hole saw collection!! That's cheating!!! A Hemi and a blower...You don't need no stinking holesaws...
...FAFO...
[Re: Thumperdart]
#2290618
04/19/17 04:18 PM
04/19/17 04:18 PM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
What exactly is involved w/ removing the crash beam from a door? Can you get in there to cut it w/o butchering the door itself? Do you cut it in 3 places....at each end to separate it from the door and the down the middle to make it easier to remove? Or do you have to drill spot welds out? Then you're left w/ holes in the door?
[Re: Thumperdart]
#2290621
04/19/17 04:26 PM
04/19/17 04:26 PM
Posts: 608 TN
1DGEMAN
TN
On my Challenger race car, I removed the glass drilled the spot welds out then cut the beam in the center with my plasma cutter. I slipped some sheet metal between the skin and beam before I cut. Worked fine.
On another note I have been looking for plastic headlamps for years and have never found any. The car has to have headlamps. Someone has to have a source.
Real Men shift for themselves
[Re: Thumperdart]
#2290635
04/19/17 05:09 PM
04/19/17 05:09 PM
hemi-itis
Is it possible to do the inside of the doors and retain the window regulator>>
[Re: skicker]
#2290636
04/19/17 05:11 PM
04/19/17 05:11 PM
hemi-itis
FMJ,when you come out,,,,,,,,,bring your hole saw collection!! That's cheating!!! A Hemi and a blower...You don't need no stinking holesaws... I have a little Jenny Craig wispering in my ear 32 hrs a day,,,,,,,,,,,
[Re: skicker]
#2290731
04/19/17 09:47 PM
04/19/17 09:47 PM
Posts: 43,232 Bend,OR USA
Cab_Burge
FMJ,when you come out,,,,,,,,,bring your hole saw collection!! That's cheating!!! A Hemi and a blower...You don't need no stinking holesaws... Yeah he does, Full size Elephant are heavy N/A Wedge motors rule Hook and Book
[Re: Cab_Burge]
#2290763
04/19/17 11:13 PM
04/19/17 11:13 PM
hemi-itis
FMJ,when you come out,,,,,,,,,bring your hole saw collection!! That's cheating!!! A Hemi and a blower...You don't need no stinking holesaws... Yeah he does, Full size Elephant are heavy N/A Wedge motors rule Hook and Book Cab,you know cause you been there & done that What's better than a boosted HEMI? And setting the block back a few inches,what's that worth?
[Re: hemi-itis]
#2290785
04/20/17 12:17 AM
04/20/17 12:17 AM
fullmetaljacket
Here's a door again, though it was done somewhat crudely, once the interior dress panel was installed, it all disappeared. This was the furthest extent that was capable of shaving some decent pounds, but still keep the door functional like stock.
#2290839
04/20/17 03:08 AM
04/20/17 03:08 AM
Cab_Burge
My hat is off to all of you street racers that have done all that work to make the cars lighter My Duster weighed 3450 lbs. with me in it, I did not build it to be light I never thought that car could or would run 10.00 on pump gas at that weight through the exhaust system on Oregon 91 octane pump swill The next one will be a lot lighter than the old one the new "pump gas" motor will make a lot more power now that I know what a good set of heads will do to make more power
[Re: Cab_Burge]
#2290882
04/20/17 09:27 AM
04/20/17 09:27 AM
fullmetaljacket
Rather quite impressive to go that fast on pump corn and at that ballast back in the day. Combo's in the modern era are so much more obtainable and manageable with great heads on top of relatively small cubes like Cab mentioned
I personally built my rig to be light based on a few reasons. First was the love for the factory hot rod effort back in the day which were turned too expensive for my wallet and sanity to own one of those gems. In the interim, what crawled into the project was the arts. This project has turned a leaf in concept and process and has become a rolling sculpture of art to be exhibited in the future believe it or not. It's just a long process in the research, planning and development in order to reach that point. Second was for reliability in a small package while it loiters out in the public. What turned out was a fast package in an even lighter set up compared to the factory hot rods themselves and probably at the price point of insanity. LOL What I can lay claim to is that it has been fun while it was incognito back in the day, but where it has been more fun is trading idea cards with y'all and only getting more funner and funnier as a civilian funny car. The one thing that I can not lay claim to is that it moves its own weightlessness on pump since it's on a steady diet of Mo-jo. Carry on guys, just don't carry the weight. LOL.
[Re: hemi-itis]
#2290943
04/20/17 11:53 AM
04/20/17 11:53 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
FMJ,when you come out,,,,,,,,,bring your hole saw collection!!In the easter/passover spirit lets get HOLY! I started using GreenLee knockouts instead of holesaws for most of my hole cutting...less chips and cleaner holes.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2291087
04/20/17 04:50 PM
04/20/17 04:50 PM
Cab_Burge
I had to buy some of Greenlee Chassis punches for my pay Phone guy back when I supervised the pay phone guys many years ago. Those punches are the cat meow Not cheap though, but no good tools are
