Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#2287995
04/15/17 12:54 AM
04/15/17 12:54 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
You can lighten the seats and keep 'em in for the tots.Me thinks a set of aluminum hood hinges and the material of choice.Ditch the latch and pin the front.Talk to Marty,he exit 62 and will help you decide what shaft won't give you the shaft.http://www.supershafts.com/ Marty is a fellow mopar man and is my go to guy.He also has the high speed balancer. If I wore my hood more often,I would put hinges on it.PITA when your parked at the cruze,one gust is all it takes,,,,,,,,,,
[Re: fullmetaljacket]
#2287997
04/15/17 12:56 AM
04/15/17 12:56 AM
hemi-itis
Al. I'll be back in town next week. Perhaps you, RMCHGR and I can Meet up. Westbuty is our destination!
#2288166
04/15/17 12:31 PM
04/15/17 12:31 PM
Posts: 1,894 Spahn Ranch
RMCHRGR
Spahn Ranch
Flat hood pin on. It's not a PITA as much as it may seem. Mine is aluminum and heavier than a glass A-team hood and I still manage to lift off and arrive back on the four pins with precision. There is simply an exercise/maneuver that makes it a breeze to lift up, swing into position and walk away. Similar moves going back on but with a touch of TLC speed to keep things from being scratched and or broken. The weight taken off the very front and high on the car is well worth it. I agree, not bummin' on other Dusters with open air systems, but a flat hood makes for some head scratching and admiration. Aluminum prop shaft from Dynotech or Mark Williams will be proper and right the first time around. There is still a few items on that pup that will bring your numbers back down. Curt "Glasses" had his Duster down to high 2900 Lbs with little done. Back seat is an option, but I'd reinstall it and look elsewhere for savings. My personal opinion of that Duster is that it should look the street car part. You could also gut it and have there for looks. Yes, it's should be around 40-50 pounds total for the seat and back cushion. Thanks Lee, that's the kind of input I was looking for. I think as it sits right now it might be pretty close to 2,900. I slept on it, back seat will go back in since I don't want a gutted interior. There's been effort made to keep the interior looking 'normal' so in keeping with that idea, the seat will stay. Hopefully my kids appreciate it! A flat pin-on hood is not something you see often, might be kinda cool. Will probably hit up the Palm Reader to make it look decent. From all I've read, I think there could be at least 40-50 lbs off the front with a glass hood and no hinges. While the interior is out, I considered a glass dash but I didn't want to create more work for myself when I'm almost at the finish line. The car has been on jack stands for over two years, it needs to be finished. Did some research on driveshafts last evening. There seems to be a lot of debate whether they are worth the price on a street car. I dunno, just kind of a better mousetrap. Trimming the dead weight seems to be the biggest benefit. Not sure what the cost/benefit is as far as ET though, seems to be minimal. Al, I've been to Marty when he was out in Mastic Beach, I actually forgot about him! Thanks for the heads up, I will give him a call.
'71 Duster '72 Challenger '17 Ram 1500
[Re: Thumperdart]
#2289067
04/16/17 09:52 PM
04/16/17 09:52 PM
hemi-itis
I only wear my hood when I go to Carlisle.It's the law ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Ask me how I know With a pin on it's a HUGE PITA to remove at the cruze in,blanket on the roof,,one good gust and,well you know.One of these days after the $$$$$$ valve slows down I would like a pair of aluminum hood hinges to go with the hood pins.
[Re: hemi-itis]
#2289091
04/16/17 10:40 PM
04/16/17 10:40 PM
RMCHRGR
Spahn Ranch
I only wear my hood when I go to Carlisle.It's the law ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) Ask me how I know With a pin on it's a HUGE PITA to remove at the cruze in,blanket on the roof,,one good gust and,well you know.One of these days after the $$$$$$ valve slows down I would like a pair of aluminum hood hinges to go with the hood pins. One-piece, tilt front end would solve ALL your issues in one stroke. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif)
[Re: hemi-itis]
#2289248
04/17/17 06:27 AM
04/17/17 06:27 AM
fullmetaljacket
Oh, Sails in the wind. Yes, I sit corrected by Hemi-itis. I've had something on the opposite side of laying it on top of the car happen with two different painstakingly gutted steel hoods with sad results. Both times I forgot to slip on the four holding pins and drove off. Now I have it mentally seared in my head as a point check no matter what. Hood is too non replaceable now.
[Re: Pale_Roader]
#2290437
04/19/17 07:26 AM
04/19/17 07:26 AM
Posts: 9,884 MI, usa
dvw
MI, usa
Have a quick question? Will removing the door beams compromise the integrity/structure ov the door any? Not talking impact here... just normal (gentle) usage. Dont want these suckers to sag or twist or do anything weird if i remove those beams.
Beams? we don't need no stinkin beams. Heck I cut the entire inner. Doug
