Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed
[Re: 70B5Cuda]
#2201190
11/23/16 01:01 PM
11/23/16 01:01 PM
Posts: 1,073 Newton, KS
70B5Cuda
Newton, KS
The engine mounts are stock pieces I purchased from Mancini. Since the mounts are not side specific, the mounting bolt is accessed from the rear side on the drivers side mount, which has plenty of clearance. Since the mount is simply reversed for the passenger side, the bolt is accessed from the front but access is difficult with the oil filter adapter in place. The 3 mounting bolts for the oil filter adapter aren't easy to get to so the solution is the remove the welded on nut on the back side of the passenger engine mount. Then I'll be able to slide the bolt in from the back side (with plenty of clearance) and use a nut/washer on the front side. The picture below shows the interference of the engine mount bolt with the oil filter adapter.
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: 70B5Cuda]
#2201893
11/24/16 03:12 PM
11/24/16 03:12 PM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#2217491
12/20/16 01:32 AM
12/20/16 01:32 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Does he have any more of these bell housing left?
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: 70B5Cuda]
#2218089
12/20/16 10:34 PM
12/20/16 10:34 PM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#2218718
12/21/16 11:48 PM
12/21/16 11:48 PM
70B5Cuda
Newton, KS
The lower control arms were boxed. I believe the plates came from PST and were something like $22 shipped. They were blasted first, then plates welded on, then powder coated in Eastwood's stamped steel. In bare metal after powder coat
[Re: 70B5Cuda]
#2228632
01/06/17 02:04 PM
01/06/17 02:04 PM
70B5Cuda
Newton, KS
I got my 6.1L heads back from the machine shop last week. These CNC ported heads were actually in the trunk of an SRT that I bought from the insurance pool. They were filthy so I had the machine shop do a valve job, replace the valve seals, and resurface them. The chambers have some nicks from a blown up piston but hey...they were free!! Plus they had upgraded PAC valve springs Intake ports Exhaust ports
[Re: 70B5Cuda]
#2234964
01/15/17 10:08 PM
01/15/17 10:08 PM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#2235215
01/16/17 11:18 AM
01/16/17 11:18 AM
70B5Cuda
Newton, KS
The passenger's side rocker had also taken quite a beating. A previous owner must have hit a pole. The damage: Closeup carnage
[Re: 70B5Cuda]
#2235216
01/16/17 11:23 AM
01/16/17 11:23 AM
70B5Cuda
Newton, KS
First I took it to a local frame shop and had them pull out the dent somewhat. I bought a new complete AMD rocker, with the hope that just a section could be used if the rest looked ok underneath.....but that's never the way that works out. The front side of the rocker was very solid. The backside...not so much
[Re: 70B5Cuda]
#2237569
01/19/17 10:10 PM
01/19/17 10:10 PM
70B5Cuda
Newton, KS
For several weeks, I would go check on progress and I would end up ordering more AMD sheetmetal. That's just the way these projects seem to go. Originally the rear crossmember, which is behind the rear bumper, was just going to get some patches. But once the bumper was off, and the rust was exposed, I ended up buying the rear crossmember, the sheetmetal right above it, and the rear corner pieces that run between the crossmember and the quarter panel. New rear crossmember. When I first got the car, I looked at the rear window channel and thought it looked pretty solid: It turns out i was wrong...
[Re: 70B5Cuda]
#2237574
01/19/17 10:22 PM
01/19/17 10:22 PM
70B5Cuda
Newton, KS
[Re: 70B5Cuda]
#2237943
01/20/17 03:05 PM
01/20/17 03:05 PM
Posts: 7,841 east side of Ohio
basketcase
east side of Ohio
figures they didn't damage the rusted area of that rocker. nice work.
1981 Dodge D150 360 auto
[Re: 70B5Cuda]
#2239198
01/22/17 04:49 PM
01/22/17 04:49 PM
70B5Cuda
Newton, KS
So much for just a patch/splice. The whole right rocker ended up coming out New AMD rocker in place
[Re: 70B5Cuda]
#2239217
01/22/17 05:03 PM
01/22/17 05:03 PM
70B5Cuda
Newton, KS
[Re: Keepat]
#2240614
01/24/17 07:17 PM
01/24/17 07:17 PM
Posts: 4,844 Wichita
GY3
Wichita
I can personally confirm that the roof has been completely stripped! Whew!
'63 Dodge 330
11.19 @ 121 mph Pump gas, n/a, through the mufflers on street tires with 3.54's. 3,600 lbs.
9.92 @ 135mph with a 350 shot of nitrous and 93 octane pump. 1.43 60 ft. 3,750 lbs.
[Re: GY3]
#2240767
01/24/17 11:32 PM
01/24/17 11:32 PM
70B5Cuda
Newton, KS
I can personally confirm that the roof has been completely stripped! Whew! Yep! Mark (GY3) has been helping me out in a big way by stripping the rubberized coating and paint from the roof, drip rails, trunk gutters, etc. I know I won't get doe by the time baby #5 arrives in late March but some real progress has been made in the last 2 weeks! Thanks Mark!
