In helping my friend initially set up his tube chassis 4 link I took the recommendation from this forum and set it up with an IC of 40/6 (if I remember correctly). He's still looking for the IC diagram I prepared when we originally set it up. Anyway the car launches good and goes straight but it is hitting the tires very soft. I need to raise the IC for a harder hit and my question is about how far should I move it per change until we're satisfied?
Thats sorta hard to answer.. sometimes a little is
a lot.. so if you move the lower front point up
2 holes that could be a ton on change.. do either
of you have a 4 link program... if you take the
time to plug all the car measurement points and do
them right you will see all the points that will be
available to you.. granted when you find the sweet
spot/area you might have a total of 4 points that
will work for most of the tracks
EDIT
For my car(short wheel base) I have a map tapped
on the wall of my trailer to show 6 different
set ups.. 4 of those work very good.. the other
2 are fair.. anything greater that those dont work
and I show the shock settings for those settings
