Re: From a Dual Plane to Single Plane
[Re: SILVER67]
#2289409
04/17/17 01:48 PM
04/17/17 01:48 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Almost any change be it exhaust, vert intake etc needs some tweaks..........some easier than others.........
[Re: SILVER67]
#2289469
04/17/17 03:23 PM
04/17/17 03:23 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Just by the nature of the design, " two planes" in which the air is trying to mix, " in halves" verus " one bigger" plane, simply cant mix the same, just as each port in any design is often different to match. EGT and O2 sensors are your friend.
With the amount of nitrous your planning on spraying, it wont even matter!
RIP Monte Smith
[Re: MR_P_BODY]
#2289730
04/17/17 10:41 PM
04/17/17 10:41 PM
Posts: 43,190 Bend,OR USA
Cab_Burge
I have changed the jets, all eight of them, in my old 440 M.W. Bracket car from late morning to mid afternoon at the old LACR track in August when the B.P. dropped three inches, the humidity increased 35 %, the air temps increased 25 F and the density altitude went up 6500 Ft., from 4500 D.A. to 11,000 DA
[Re: SILVER67]
#2289754
04/17/17 11:10 PM
04/17/17 11:10 PM
Posts: 4,206 New York
polyspheric
New York
Generally the vacuum loss (much larger plenum volume) needs more fuel. Exhaust re-breathing with big overlap becomes worse; idle quality goes down; stall speed with the same converter is down. Primary PV may need to be lower. Sometimes +5 degrees initial lead helps (deduct from the curve for the same total).
Boffin Emeritus
