If you have a decent set of dial calipers or a good miikecrometer with a ball end measure the piston pin to the piston decks first and write that down, once you check all four corners with the same rod and piston to determine block deck height variance in relation to the same piston and rod then install the other seven and find out how much variances you see on them.
You really need a four inch stroke dial indicator to accurately measure the stroke differences on each rod journal on any non stroker BB Mopar motor
I think you will find most of the variances in the deck heights will be in the stock rod lengths
I've seen .017 differences in rod lengths with the same forging numbers from mixed rods from different RB motors
I've also seen .020 stroke differences on a crank that had been welded and repaired from a spun rod bearing
BTW, is the name your trying to think of called "engine blue printing" ?
Good luck on your venture for information
