Re: TSB for Fuel Pump Bypass Kit?
[Re: Mattax]
#2288264
04/15/17 03:20 PM
04/15/17 03:20 PM
Posts: 25,741 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The kit was originally listed for use on '65-'68 Dodge trucks, vans and wagons with the /6. '69 CHP 440 cars had it installed.
The nipple for the crossover hose has a tiny orifice that allows fuel to loop around from the pressure side of the pump to the suction side. The small amount of fuel bypassed doesn't affect performance but it does allow trapped pressure in the fuel delivery line to bleed off after engine shutdown.
The 1973 TSB probably advised the use of an earlier kit to solve a later problem.
