Page 1 of 6 1 2 3 4 5 6
Shootin for my 9-second slip.....FINALLY... #228812
02/18/09 03:43 PM
02/18/09 03:43 PM
State of confusion
Thumperdart Offline OP
State of confusion
I`ve been checking the weather for Famoso several times a day for weeks and it looks like it might be a go so, based on my new sig numbers, does anyone care to take a stab at my HOPEFUL 9-sec. et? My best of 10.09 in may of 05 looked like this; 1.414 60 ft.
4.093 330
6.387 1/8th @ 107.12
10.09 @ 131.97 mph.....So, based on my old #`s compared to my sig #`s what do you guys think? THANKXX.......... Forgot...if it matters my new 330 et was 3.983....
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228813
02/18/09 03:45 PM
02/18/09 03:45 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
9.836
Re: Shootin for my 9-second slip.....FINALLY... [Re: Bigcube] #228814
02/18/09 03:50 PM
02/18/09 03:50 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
10.001
I'm bettin you miss a shift
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228815
02/18/09 03:51 PM
02/18/09 03:51 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
9.901.. Ready to race super gas
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Shootin for my 9-second slip.....FINALLY... [Re: WILD BILL] #228816
02/18/09 03:52 PM
02/18/09 03:52 PM
State of confusion
State of confusion
Now that just ain`t right Wild Bill. I like BigCubes guess better.
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228817
02/18/09 03:57 PM
02/18/09 03:57 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Not a guess, just math
10.09/6.387=1.57977
1.57977*6.223=9.830
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228818
02/18/09 04:06 PM
02/18/09 04:06 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Whoever accused me of being right
Good luck
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228819
02/18/09 04:10 PM
02/18/09 04:10 PM
ohio
1Bad440 Offline
1Bad440  Offline
ohio
Thump, This is 1 of my passes
60' 1.356
330' 3.997
660' 6.242 108.86 mph
1000' 8.210
1320' 9.887 135.02 mph
If it don't lay down in high gear your there easy
Re: Shootin for my 9-second slip.....FINALLY... [Re: 1Bad440] #228820
02/18/09 04:14 PM
02/18/09 04:14 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
9.82@137MPH
Good Luck!!
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228821
02/18/09 04:14 PM
02/18/09 04:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm gonna say 9.86... I'm thinkin it will fall off
a touch on top end at a 135mph
Re: Shootin for my 9-second slip.....FINALLY... [Re: 1Bad440] #228822
02/18/09 04:17 PM
02/18/09 04:17 PM
State of confusion
State of confusion
Sorry BigCube, I should know better ........1bad440, my car is a 1/4 mile car w/the 4.11`s and I`ve been playing on the 1/8th to tune it. Man, you and I are neck and neck in et. Thankxx again and hopefully the weather holds out for us cos that`s a LONG haul.
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228823
02/18/09 04:33 PM
02/18/09 04:33 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
If you can run 6.22 at 109 you should go 9.80's at around 134-136
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228824
02/18/09 04:38 PM
02/18/09 04:38 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We're testing at Famoso on Saturday. I'll try to watch for you. We're looking for 6.79/208 or better.
Re: Shootin for my 9-second slip.....FINALLY... [Re: BobR] #228825
02/18/09 04:52 PM
02/18/09 04:52 PM
State of confusion
State of confusion
Thankxx...........I`ll look for ya Bob and wish you guys the best.
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228826
02/18/09 05:28 PM
02/18/09 05:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
should be good for an easy mid 12 pass
Re: Shootin for my 9-second slip.....FINALLY... [Re: Quicktree] #228827
02/18/09 05:32 PM
02/18/09 05:32 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It should go 9.80's easily, based on your past exploits.
Had you been running a stroked smallblock, this would have happened in Biblical times for you already
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Shootin for my 9-second slip.....FINALLY... [Re: B3422W5] #228828
02/18/09 05:36 PM
02/18/09 05:36 PM
State of confusion
State of confusion
If I had a smallblock the way I build em, I`d still be in the 11`s. I`m gonna ignore Slowtrees comment.
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228829
02/18/09 05:38 PM
02/18/09 05:38 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
And you thought I wasn't right
Re: Shootin for my 9-second slip.....FINALLY... [Re: WILD BILL] #228830
02/18/09 05:40 PM
02/18/09 05:40 PM
State of confusion
State of confusion
It probably will go 10.000 and then I`ll tap into the Millers and call it good and then sell the pig.
Re: Shootin for my 9-second slip.....FINALLY... [Re: B3422W5] #228831
02/18/09 05:46 PM
02/18/09 05:46 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Slam dunk 9.86 136. I Understand your improvement came from just leaving at a higher rpm off the converter?
