Re: Best way to repair 69 Charger grille pastic????
[Re: Charger43]
#2288152
04/15/17 12:14 PM
04/15/17 12:14 PM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Do you know if the broken area is ABS plastic? I repaired a motorcycle trim piece to perfection- actually had to build in a missing chunk. I took a separate piece of ABS and sanded it to create dust. I mixed the ABS dust with acetone to make a thick slurry. I used this slurry to glue in a piece needed to make the part whole. I didnt just apply slurry in the crack but applied to both sides as well. When it cured I sanded/blended to perfection- used a high build primer for sand scratches and the end result was an undetectable repair.
Keep old mopars alive.
[Re: Charger43]
#2288242
04/15/17 02:49 PM
04/15/17 02:49 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Anyone know the best way to repair 69 Charger grill plastic? Classic has a nice complete INJECTION MOLDED PLASTIC grille available just like ORIGINAL, either that, or repair it as member 2boltmain has described above IMHO for the price of the Classic grille you'd be light years ahead of the project
[Re: DAYCLONA]
#2290107
04/18/17 04:28 PM
04/18/17 04:28 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
Anyone know the best way to repair 69 Charger grill plastic? Classic has a nice complete INJECTION MOLDED PLASTIC grille available just like ORIGINAL, either that, or repair it as member 2boltmain has described above IMHO for the price of the Classic grille you'd be light years ahead of the project 25% off right now too (until 4/19)
1968 Charger R/T, 440 Auto, GG1; 1969 Super Bee, 383, 4-speed, T5; 1969.5 Road Runner, 440-6, 4-speed, 96; 1970 Duster 340, 4-speed, EV2; 1970 Charger R/T SE, 440 (496), Auto, EB3; 1970 Dart Swinger 340 (416), 4-speed, EV2; 1970 Corvette coupe, LS5, 4-speed, Daytona yellow; 2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
