Diaper or Catch Pan For Early B-Body #2287663
04/14/17 01:54 PM
04/14/17 01:54 PM
tboomer Online work OP
tboomer  Online Work OP
Whats the preference here? Diaper or Catch pan for my 64? Pictures would be great! Thanks!! Ted wave
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2287796
04/14/17 06:08 PM
04/14/17 06:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ted.. there is no best answer here.. its what will
work easiest for you.. they both will do the same
job if done right.. on my junk the pan is easier..
and smooths out the air flow under the car... for
others the diapers are easier but make sure you get
one that wont burn in high temp areas and no plastic
strap connections.. I remember one that Hemi Fred had
that has plastic parts that didnt last
wave
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2287814
04/14/17 06:46 PM
04/14/17 06:46 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've had the same plastic buckles on mine going on three years now... no probs (100+ passes last year alone so it's been in the field being used). location, location, location smile that said I went with a diaper, but I also had the car modified to allow the easy use of such products.
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2287819
04/14/17 06:51 PM
04/14/17 06:51 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ted give Glen (Wyoming) a shout. Believe he has a blanket and runs an older B with a big block like yourself.
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2287849
04/14/17 08:28 PM
04/14/17 08:28 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Hey Ted get DVW (Doug) to post some pictures of his diaper. VERY NICE!!!!!!!!!!!
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Diaper or Catch Pan For Early B-Body [Re: pittsburghracer] #2287863
04/14/17 08:54 PM
04/14/17 08:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The reason the pan would have worked best for my
W-9 engine was that it was a dry sump engine so the
pump and lines would clear much easier with a pan and
it wouldnt have a expiration date like some of the
diapers and it would help smooth out ail flow under
the car.. but now that engine is sold and I can go
with what ever I want and that MIGHT be a pan again
wave
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2287883
04/14/17 09:37 PM
04/14/17 09:37 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I made a drawing of my pan and sent it to Rustler. Fit near perfect. Going on its 5th year.
Doug
Re: Diaper or Catch Pan For Early B-Body [Re: dvw] #2287928
04/14/17 11:03 PM
04/14/17 11:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug
Doug.. how many degrees of temp does that hold in it
wave
Re: Diaper or Catch Pan For Early B-Body [Re: dvw] #2287931
04/14/17 11:09 PM
04/14/17 11:09 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Doug
Where's the like button? Very nice! up
Re: Diaper or Catch Pan For Early B-Body [Re: Bigcube] #2287934
04/14/17 11:14 PM
04/14/17 11:14 PM
PA.
"Little"John
"Little"John
PA.
For the guys running alcohol a diaper is a win win.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Diaper or Catch Pan For Early B-Body [Re: pittsburghracer] #2288406
04/15/17 08:31 PM
04/15/17 08:31 PM
Thanks guys! That Russler looks like a great fit! wave
Re: Diaper or Catch Pan For Early B-Body [Re: MR_P_BODY] #2288516
04/16/17 12:02 AM
04/16/17 12:02 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Doug
wave
It has a heck of a time getting oil temp above 150 before a run. never seen it over 180' I actually have thought about a pan heater.
Doug
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2288756
04/16/17 12:58 PM
04/16/17 12:58 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Nice to hear you liked Russ's work Doug. I'll show him the picture. He's a great guy, and an old nostalgia racer himself.
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2289013
04/16/17 08:05 PM
04/16/17 08:05 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I have the Rusler also. Fits great, but on a filled block I had to add an oil cooler to keep mine cool on street drives.
Fits great, and does a nice job for sure though.
Re: Diaper or Catch Pan For Early B-Body [Re: dizuster] #2290155
04/18/17 06:27 PM
04/18/17 06:27 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Pan on my 64 hemi car
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Diaper or Catch Pan For Early B-Body [Re: HemiDart68] #2290246
04/18/17 09:10 PM
04/18/17 09:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Looks good, might do one on my 64, how deep is your oil pan? Is there any absorbent material in the box? Aluminum or steel? How high up or deep is it, hard to tell from pic? For the rest of you guys, which one would contain the oil better, flying parts not the problem. And Mr P, why would you need a diaper for a dry sump? Granted you'll lose some but not the gully washer of a 8-10 quart pan.
Re: Diaper or Catch Pan For Early B-Body [Re: cudaman1969] #2290282
04/18/17 10:14 PM
04/18/17 10:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt want a diaper I wanted to build pan
and to my understanding I was told that even
the pump was to be with in the diaper if you
went that way
wave
Re: Diaper or Catch Pan For Early B-Body [Re: cudaman1969] #2290497
04/19/17 11:18 AM
04/19/17 11:18 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
My pan is a 10qt charlies pan. I think its around 10 inch's deep. My Kframe is cut and boxed square. The object was to get the catch pan to fit tightly around the K frame opening. Thus the K frame would also act as part of the pan, and runoff from the k frame would go into the pan. It is powder coated aluminum. the pan sits less than 1/2 inch lower then the pan so there is room for absorbant material. I put a few layers of absorbant material in it and used speed tape to tape it down.
Re: Diaper or Catch Pan For Early B-Body [Re: HemiDart68] #2290835
04/20/17 03:02 AM
04/20/17 03:02 AM
BigFish69 Offline
BigFish69  Offline
Matt
whats the rear of the pan bolted to I see the front is bolted to the K member any rear pics
thanks Tom
Re: Diaper or Catch Pan For Early B-Body [Re: tboomer] #2290887
04/20/17 09:49 AM
04/20/17 09:49 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do you have any thoughts on closing the sides of the K member to direct oil to the sump?
