Re: Diaper or Catch Pan For Early B-Body
[Re: tboomer]
#2287796
04/14/17 06:08 PM
04/14/17 06:08 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Whats the preference here? Diaper or Catch pan for my 64? Pictures would be great! Thanks!! Ted Ted.. there is no best answer here.. its what will work easiest for you.. they both will do the same job if done right.. on my junk the pan is easier.. and smooths out the air flow under the car... for others the diapers are easier but make sure you get one that wont burn in high temp areas and no plastic strap connections.. I remember one that Hemi Fred had that has plastic parts that didnt last
[Re: tboomer]
#2287849
04/14/17 08:28 PM
04/14/17 08:28 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Whats the preference here? Diaper or Catch pan for my 64? Pictures would be great! Thanks!! Ted Hey Ted get DVW (Doug) to post some pictures of his diaper. VERY NICE!!!!!!!!!!!
[Re: pittsburghracer]
#2287863
04/14/17 08:54 PM
04/14/17 08:54 PM
MR_P_BODY
The reason the pan would have worked best for my W-9 engine was that it was a dry sump engine so the pump and lines would clear much easier with a pan and it wouldnt have a expiration date like some of the diapers and it would help smooth out ail flow under the car.. but now that engine is sold and I can go with what ever I want and that MIGHT be a pan again
[Re: dvw]
#2287931
04/14/17 11:09 PM
04/14/17 11:09 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
I made a drawing of my pan and sent it to Rustler. Fit near perfect. Going on its 5th year. Doug Where's the like button? Very nice!
[Re: Bigcube]
#2287934
04/14/17 11:14 PM
04/14/17 11:14 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
For the guys running alcohol a diaper is a win win.
[Re: MR_P_BODY]
#2288516
04/16/17 12:02 AM
04/16/17 12:02 AM
Posts: 9,871 MI, usa
dvw
MI, usa
I made a drawing of my pan and sent it to Rustler. Fit near perfect. Going on its 5th year. Doug Doug.. how many degrees of temp does that hold in it It has a heck of a time getting oil temp above 150 before a run. never seen it over 180' I actually have thought about a pan heater. Doug
[Re: HemiDart68]
#2290246
04/18/17 09:10 PM
04/18/17 09:10 PM
Posts: 8,343 fredericksburg,va
cudaman1969
fredericksburg,va
Looks good, might do one on my 64, how deep is your oil pan? Is there any absorbent material in the box? Aluminum or steel? How high up or deep is it, hard to tell from pic? For the rest of you guys, which one would contain the oil better, flying parts not the problem. And Mr P, why would you need a diaper for a dry sump? Granted you'll lose some but not the gully washer of a 8-10 quart pan.
[Re: cudaman1969]
#2290282
04/18/17 10:14 PM
04/18/17 10:14 PM
MR_P_BODY
Looks good, might do one on my 64, how deep is your oil pan? Is there any absorbent material in the box? Aluminum or steel? How high up or deep is it, hard to tell from pic? For the rest of you guys, which one would contain the oil better, flying parts not the problem. And Mr P, why would you need a diaper for a dry sump? Granted you'll lose some but not the gully washer of a 8-10 quart pan. I didnt want a diaper I wanted to build pan and to my understanding I was told that even the pump was to be with in the diaper if you went that way
[Re: cudaman1969]
#2290497
04/19/17 11:18 AM
04/19/17 11:18 AM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Looks good, might do one on my 64, how deep is your oil pan? Is there any absorbent material in the box? Aluminum or steel? How high up or deep is it, hard to tell from pic? For the rest of you guys, which one would contain the oil better, flying parts not the problem. And Mr P, why would you need a diaper for a dry sump? Granted you'll lose some but not the gully washer of a 8-10 quart pan. My pan is a 10qt charlies pan. I think its around 10 inch's deep. My Kframe is cut and boxed square. The object was to get the catch pan to fit tightly around the K frame opening. Thus the K frame would also act as part of the pan, and runoff from the k frame would go into the pan. It is powder coated aluminum. the pan sits less than 1/2 inch lower then the pan so there is room for absorbant material. I put a few layers of absorbant material in it and used speed tape to tape it down.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
