Re: Diaper or Catch Pan For Early B-Body
[Re: BigFish69]
#2291001
04/20/17 01:34 PM
04/20/17 01:34 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Matt whats the rear of the pan bolted to I see the front is bolted to the K member any rear pics thanks Tom For the rear we used an aluminum plate bolted to the transmission, in place of the torque converter inspection plate/cover that hangs down the depth of the pan. The plate has mounting provisions that the rear of the belly pan bolted up to.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
[Re: Clanton]
#2291008
04/20/17 01:48 PM
04/20/17 01:48 PM
HemiDart68
North of Detroit
Do you have any thoughts on closing the sides of the K member to direct oil to the sump? I have thought about doing that. The NHRA rule book for belly pans states something along the lines of the pan covering from frame rail to frame rail. Easy in a chassis car or dragster, not possible in a stock front suspension. I think closing off the K frame on the sides could bring it more in-line the rule, and the argument could be made that by utilizing the k frame and oil catch pan in this manner meets the intent of the frame rail to frame coverage. Might end up making block off plates at some point, especially if I raced regularly. I'm more interested in have a street car lately. I know a few people with similar setups that race regularly and never had an issue with tech. Its all about doing the best you can, no setup diaper or pan is perfect when dealing with stock suspension mopar with a steering link going through the pan.
[Re: tboomer]
#2291386
04/21/17 01:36 AM
04/21/17 01:36 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Been thinking about this all afteroon I really like that belly pan that fits in the notched "k".But the diaper also cover the sides of the block.If something blows hard enough to go through the oil pan it will go through that pan also,,,,,,,,
[Re: hemi-itis]
#2291747
04/21/17 07:30 PM
04/21/17 07:30 PM
Posts: 8,354 fredericksburg,va
cudaman1969
fredericksburg,va
Been thinking about this all afteroon I really like that belly pan that fits in the notched "k".But the diaper also cover the sides of the block.If something blows hard enough to go through the oil pan it will go through that pan also,,,,,,,, Maybe some Kevlar sheets glued to that pan
[Re: dvw]
#2292027
04/22/17 11:57 AM
04/22/17 11:57 AM
Posts: 422 montana
BANDIT
montana
Not to hi-jack but DRW, is that an Aerospace mandrel for your alt and vacuum pump? I noticed you have a spacer holding it away from the crank trigger wheel. I am wondering how to do mine without having everything all bolted together as one unit. Jim.
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
