PSO Heads #2287673
04/14/17 02:05 PM
04/14/17 02:05 PM
usa,pa
jkwedge540 Offline OP
usa,pa
Anyone ever have a set of PSO B1's done by muscle motors? Do the y do there own port work?
Re: PSO Heads [Re: jkwedge540] #2287781
04/14/17 05:51 PM
04/14/17 05:51 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I'm sure Mike knows what he is doing.
I've seen the a set from Best Machine and they looked real good.
I know Scott at Koffels with do a set from time to time.
Re: PSO Heads [Re: jkwedge540] #2287800
04/14/17 06:14 PM
04/14/17 06:14 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Id ck with Bob from modern cylinder head
Re: PSO Heads [Re: jkwedge540] #2287802
04/14/17 06:19 PM
04/14/17 06:19 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Ask gup or silverfish how did theirs .
Re: PSO Heads [Re: jkwedge540] #2287945
04/14/17 11:24 PM
04/14/17 11:24 PM
usa,pa
usa,pa
Just not sure about buying these heads that muscle motors did. Would muscle have done all the machining on them, or would modern have. I ask the guy if he could send one head to best machine so they could check it out before I purchased them, just does not seem to what to do it. Should I be concerned?
Re: PSO Heads [Re: jkwedge540] #2287988
04/15/17 12:44 AM
04/15/17 12:44 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
I bought a set from MM.
I don't know who did the port work but heads were junk!!!!
Have Best Machine, Modern or Slawko do them.
Had to have major rework to make them usable.
Ran 1/2 hour and dropped a valve seat.
They used 3/8-16 helicoils for rocker pedestals and they pulled out.
I had to have 1/2-13 Tine Certs installed.
No heli coils for intake bolts, just threaded the heads.
No heli coils for headers, just threaded the heads.
Sloppy install of the pushrod tubes.
Had to have rocker pedestals cut .070 to correct geometry.
They were pretty much unusable as received.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: PSO Heads [Re: jkwedge540] #2288025
04/15/17 01:48 AM
04/15/17 01:48 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Slawko did guppy's and I believe self racing did silverfish.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: PSO Heads [Re: 1967dartgt] #2288067
04/15/17 05:56 AM
04/15/17 05:56 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
If I was having some done, I'd send them to Slawko or Modern. Both will require you to source castings
Alan Jones
Re: PSO Heads [Re: jkwedge540] #2288097
04/15/17 09:54 AM
04/15/17 09:54 AM
usa,pa
usa,pa
These are a completed head with port work valves, and rocker arms. They are ready to go.
Re: PSO Heads [Re: steve660] #2288099
04/15/17 09:56 AM
04/15/17 09:56 AM
usa,pa
usa,pa
Steve did mm fix the heads for you?
Re: PSO Heads [Re: jkwedge540] #2288222
04/15/17 02:22 PM
04/15/17 02:22 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Muscle Motors is ok by me
Re: PSO Heads [Re: jkwedge540] #2288550
04/16/17 01:21 AM
04/16/17 01:21 AM
Lowes
steve660 Offline
steve660  Offline
Lowes
They repaired the dropped seat.
The rest I had repaired locally.
Re: PSO Heads [Re: 1967dartgt] #2288835
04/16/17 02:24 PM
04/16/17 02:24 PM
Idabel,Oklahoma
Gary Robbins Offline
Idabel,Oklahoma
Slawko cnc'd mine and Self Racing finished as they built the engine...You'll get into lots of custom stuff making everything work right(rocker geometry-spacer under valve covers-intake spacer,etc,etc)
Mine are 80hp better than my originals that was on a n/a combo and PSO setup is a true nitrous deal...Engine builder said we're leaving between 50-75hp on the table with all the nos tricks !!
Not sure it's worth the coin yet as I just got mine back and it looks like I have to redo the headers also !!
Re: PSO Heads [Re: jkwedge540] #2288845
04/16/17 02:35 PM
04/16/17 02:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Slawko has a great program for them. I plan to use Slawko for mine, my predator stuff is off and there now as well.
