Alternator feed to battery, interference?
#2286352
04/12/17 12:19 PM
04/12/17 12:19 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
I'm currently doing some rewiring on my car and have been simplifying a lot of things. I have a one wire alternator w/ the wire run underneath the car all the way back to the battery in the trunk and it works great. I'd like to shorten that wire by attaching it to a junction block (pictured below) I have mounted on the firewall where the main 1/0 wire from the battery attaches to the starter wire. Also have a wire feeding all of my electrical components (ignition, nitrous, etc.) taken from this junction block.
My question is will there be any interference issue w/ these somewhat sensitive components if I let the alternator feed back to the battery at this point? Or does that long run back to the battery and then the battery wire run all the way back to the front of the car eliminate any possible interference? It's all attached to the battery positive, just a matter of where it connects.
Could I even connect it to the starter relay where it gets battery power on the big stud? That would make an even shorter run.
Excuse me if this is a stupid question, I'm learning as I go w/ a lot of this wiring stuff, lol.
![Name: wire stud.jpg
ID: 280734 wire stud.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/280734/filename/wire stud.jpg)
Re: Alternator feed to battery, interference?
[Re: an8sec70cuda]
#2286374
04/12/17 12:57 PM
04/12/17 12:57 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm wired the same way as your talking.. both on the race car and the Rampage.. it works fine so far.. I'm putting on full fuel injection now so I will see how it is with that type of electronics ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Dodgeguy101]
#2286384
04/12/17 01:11 PM
04/12/17 01:11 PM
an8sec70cuda
If you do that, will it not still make the wire hot and let the engine run, even if you turn the battery disconnect switch off in the back of the car?
I don't know the answer, but just throwing it out there. Yep, you're right. Didn't even think of that! Thanks yall, but it looks like I'll have to leave it the way it is.
[Re: an8sec70cuda]
#2286394
04/12/17 01:28 PM
04/12/17 01:28 PM
MR_P_BODY
On mine I come from the alt to the master then out of the master to the battery then forward to the hot post.. ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: an8sec70cuda]
#2286446
04/12/17 03:02 PM
04/12/17 03:02 PM
Posts: 11,739 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Connecting the alternator feed to the same stud as everything else in the car will eliminate the function of the master switch. The alternator will keep everything running until the engine shuts off. Battery and alternator feed on one side of the master, everything else on the other. That's the simple and effective way to do it. Because of the long run, use a larger gage of wire for the alternator, minimum of 8ga. Also, because the alternator line is now hot all the time, take time too ensure that wire is well insulated and protected to keep it form being shorted to ground.
[Re: an8sec70cuda]
#2286451
04/12/17 03:12 PM
04/12/17 03:12 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
I have mine wired up like you are wanting to do. I do use a continuous duty solenoid to interrupt the alternator feed though. It does take some extra wiring to make the solenoid work right with the key and everything but the charging system is something I don't ever worry about anymore.
68 Barracuda Formula S 340
[Re: an8sec70cuda]
#2286455
04/12/17 03:19 PM
04/12/17 03:19 PM
an8sec70cuda
It's been this way for 11 years w/ no issues...big wire run back to the battery from the alternator.
I started off rewiring my nitrous system to add a progressive and it kinda snowballed. I've gotten rid of a bunch of old crap wiring, simplified a bunch of stuff, and throughout this whole deal I've been trying to take some weight off this sled of a car so I can hopefully run a lil faster.
I wish I wasn't so attached to this particular car, but I am, so I'll just have to do what I can w/ it. Otherwise I'd sell it rolling, buy the '68 fastback cuda I've had my eye on, and actually have a car that's light. But I've had this car for so long and done so much w/ it, I'll never part with it.
[Re: an8sec70cuda]
#2286587
04/12/17 08:27 PM
04/12/17 08:27 PM
Bad340fish
Tulsa OK
If this makes you feel better my 68 Fastback weighs 3600lbs with my 240lb rear in it and an all Iron(r1 block) small block. lol
[Re: an8sec70cuda]
#2286923
04/13/17 10:23 AM
04/13/17 10:23 AM
an8sec70cuda
LOL, ok, that does make me feel a lil better! I've lost almost 10 lbs myself...down to a svelte 325 lbs now, lol. I need to get Ray (sixpackgut) to drive this thing. I'm seriously thinking about removing the windshield wiper system since I never drive it in the rain anymore. It desperately needs to lose weight, but I refuse to gut the interior of the seats, door panels, etc. I've even been shortening bolts that hold various things on, lol.
Everyone thinks the all aluminum hemi saved me a bunch of weight, but it didn't at all. It weighs the same as the iron block/aluminum headed 440 it replaced.
[Re: an8sec70cuda]
#2287216
04/13/17 07:39 PM
04/13/17 07:39 PM
Bad340fish
Tulsa OK
I use that same switch but I use the small poles to kill the solenoid on the alternator output.
[Re: Bad340fish]
#2288229
04/15/17 02:32 PM
04/15/17 02:32 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I like using the 2 pole switch(4 post) also, but route the ignition control (MSD small red wire not the big lead) through the aux pole of the switch.
Then the alternator can be connected forward in the car for less cable length and voltage drop, and no need for heavy relays.
Also when wired this way every thing in the car is dead forward of the bettery disconnect when the switch is thrown. Lots of ways to get the job done.
"Just a Bracket car dressed up like a streetcar"
[Re: an8sec70cuda]
#2288489
04/15/17 11:06 PM
04/15/17 11:06 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Chip, if you have a dedicated cable to the starter, you can run your alternator wire to the starter cable stud, also. Leave your ignition system and fuel system wired as is, because they need to power up through the kill switch.
[image][/image]
[Re: Bad340fish]
#2290150
04/18/17 06:11 PM
04/18/17 06:11 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I have mine wired up like you are wanting to do. I do use a continuous duty solenoid to interrupt the alternator feed though. It does take some extra wiring to make the solenoid work right with the key and everything but the charging system is something I don't ever worry about anymore. I did the same thing, ran a 4ga copper clad aluminum wire to the back with a continuous duty RV type solenoid.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
