Re: Afco 3850 coilover spring question
[Re: Leigh]
#2285801
04/11/17 01:15 PM
04/11/17 01:15 PM
Posts: 11,754 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You are probably using a spring with a lighter spring rate and have the spring compressed some by winding the spring seat up to maintain correct shock length and ride height. That's not wrong or a bad thing like some would say. It's a tuning choice based on your combination and how you want to set the suspension up. When doing that, we try to use a better quality spring and check them occasionally, changing them out when when needed. If they lose ANY free length, they go into the can. That will help keep them from deflecting and tearing up the shock.
