from setting the timing & getting a piston up against the stop to tighten the dampener bolt I probably turned the crank 2 turns max total. The cam was gooped with Hughes' lube that smelled like rear axle sure grip additive then when I was priming it I noticed that the lobe I could see appeared to be wet with oil/the paste wiped off so it hit me that they all must be like that now. will this be an issue? should I pull the intake or fire it up? thank you for your time.
I don't think you should have any issues, fire it up!
I have "been there" many times and used to think the cam stuff had to best to use. Right?
I like you hated to see it run off. So at first I started using white lithium grease a idea I am sure I read from a magazine somewhere. Did I bet 8-10 or more back in the day with no failures.
Then I started using black moly paste and have built many more engines and swear by the stuff for use on cams.
Good to have white lithium or moly paste on both ends of the pushrod too.
Neither of the above will ever run off, not even years later.
Good luck with your fire up!
I also have just dumped a can of STP oil treatment(sometimes it was called motor honey)right over the whole dry cam and lifters before putting on the manifold with no trouble.
