Re: 2014 Ram tail light issue
[Re: LimeliteAero]
#2284788
04/09/17 01:58 PM
04/09/17 01:58 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
did you check for power at the contacts first? check the ground, and then the wiring.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: LimeliteAero]
#2284800
04/09/17 02:30 PM
04/09/17 02:30 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Does it have a hitch and wiring?If so look at the connector.They love to corrode.had problems with my sons when we hooked up the trailer as some lights did not work because the connector under the bed was corroded.rocky
Chrysler Firepower
[Re: LimeliteAero]
#2284860
04/09/17 04:16 PM
04/09/17 04:16 PM
RapidRobert
if this is the std 1157 dual filament bulb which the large filament is for brakes/TS and the small one for running lights & you have no running lights on that side correct? that (running lights) is a 1 wire circuit so if one side is good then there has to be power back to the rear to wherever it T's at
[Re: LimeliteAero]
#2285066
04/09/17 10:56 PM
04/09/17 10:56 PM
therocks
Niles , Ohio
14 did they have intigrated circuit where one wire powers up through strips in the assembley?I know we had a few that we had to replace the housing.My nephew has a 10 caravan and has trouble with rt tail light at times.Then at times his stop/turn dosent work right.Tried a new socket and it works for awhile then does the same. Rocky
Chrysler Firepower
