Re: A-Body Drive Shaft Length Question - Duster Dart
[Re: vinnyd76]
#2284673
04/09/17 03:18 AM
04/09/17 03:18 AM
Posts: 8,306 fredericksburg,va
cudaman1969
fredericksburg,va
I would think the 70 would be the same length as a 67-69 (same wheelbase) my Barracuda is 44.88" and 3" diameter. I have two Dart shafts that I'll measure tomorrow but they are 3" also and about 3" longer say 47.88" in that area. Not even sure the big joint was offered in an A-body after 69, I'll look at your chart again, what is the body code for dart? Down at bottom of chart 70 7260 small joint 47.99 3.25 Dusters are same as Barracuda length, Darts have longer wheelbase. 3" longer
[Re: cudaman1969]
#2284680
04/09/17 03:39 AM
04/09/17 03:39 AM
Posts: 1,564 Macomb, MI
vinnyd76
Macomb, MI
I would think the 70 would be the same length as a 67-69 (same wheelbase) my Barracuda is 44.88" and 3" diameter. I have two Dart shafts that I'll measure tomorrow but they are 3" also and about 3" longer say 47.88" in that area. Not even sure the big joint was offered in an A-body after 69, I'll look at your chart again, what is the body code for dart? Down at bottom of chart 70 7260 small joint 47.99 3.25 Dusters are same as Barracuda length, Darts have longer wheelbase. 3" longer The body code for a Dart is "L" according to the legend. Thank you very much for the help!
