Jeep won't idle in reverse
#2284404
04/08/17 02:07 PM
04/08/17 02:07 PM
Posts: 5,395 Pikes Peak Country
TC@HP2
Pikes Peak Country
'98 Jeep Grand Cherkoee Limited, 5.2, full time 4wd.
Picked this up cheap. Had a blown engine so no ability to test drive before purchase. Swapped the engine out and it fired up, idle great, drove it around the neighborhood no problem. When it came time to back it into the driveway, it wouldn't idle in reverse. Sputters, coughs, dies, but no idle in reverse at all. Idle in park, neutral, or drive is fine.
Suggestions on things to check?
Re: Jeep won't idle in reverse
[Re: TC@HP2]
#2284470
04/08/17 04:58 PM
04/08/17 04:58 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Can you keep it running if you apply the brakes with your left foot and use the throttle to keep it running?
[Re: TC@HP2]
#2284814
04/09/17 02:52 PM
04/09/17 02:52 PM
John_Kunkel
Rio Linda, CA
The transmission line pressure increases by a factor of 3 in Reverse, this adds to the engine's load so an engine with tuneup problems might not run correctly with the added load of the transmission pump and could stall.
[Re: John_Kunkel]
#2284817
04/09/17 02:58 PM
04/09/17 02:58 PM
Posts: 21,855 Kirkland, Washington
Pacnorthcuda
Wow---that's pretty obscure stuff John! Never heard of that. So it's possible for idle in reverse to be a bit lower than in drive? Interesting. Learn something every day.
[Re: TC@HP2]
#2285285
04/10/17 01:38 PM
04/10/17 01:38 PM
Posts: 20,704 in a cattle trailer down by th...
Guitar Jones
Yeah, pressure is high in reverse. This can cause fluid to bypass some seals. Sounds like the torque converter clutch is being applied, at least partially. This could be a converter problem or it could be in the trans. I seriously doubt it would be wiring related.
[Re: TC@HP2]
#2285810
04/11/17 01:38 PM
04/11/17 01:38 PM
Guitar Jones
Nearly anything is possible. 42 years in this business and I still see stuff I've never seen before. I don't think it's misalignment and blowing the cooler lines out probably won't help. It wouldn't hurt to check the cooler flow though. Even if that caused a seal to bypass fluid the damage is probably already done and it will need to be repaired.
[Re: TC@HP2]
#2286776
04/13/17 12:36 AM
04/13/17 12:36 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Check crank sensor for intermittent signal. I had a Ram pickup so this same thing a few years ago and found the CKP to be defective.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2287405
04/14/17 12:41 AM
04/14/17 12:41 AM
Posts: 865 Southeast Pa.
SALEM1912
Southeast Pa.
X2 with Guitar Jones. One thing to look at is the trans converter engaging. Try feathering the gas in a parking lot and see if the Jeep takes off like a stick shift truck,it may take a few times. You must understand hyd pressure hold OFF the converter clutch any low line pressure from wear plus reverse needing more pressure adds to a drop in pressure enough to cause the clutch to engage and stall the engine. BTW it's not a faulty converter it would be a wear problem most of the time in the frt pump area. IMO
