Page 2 of 5 1 2 3 4 5
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2283862
04/07/17 11:43 AM
04/07/17 11:43 AM
Ohio
70BIRD Offline
70BIRD  Offline
Ohio
I have an RB 493 CI 6 pack stroker in my road runner that Nick Wilson built for me about 4 or 5 years ago. The intake had a stage II porting done by Hughes and it made 734HP at 6,950 RPM and around 640 foot pounds torque. THere was a thread from back then where I posted the dyno sheet if your interested.
Paul
Re: Recipe for 700hp six pack 440 or bigger- [Re: dwayne welder] #2283868
04/07/17 11:53 AM
04/07/17 11:53 AM
Sask, Can.
72demon416 Offline OP
Sask, Can.
I'll keep that intake in mind - thanks!
My only constraint is it has to fit under the shaker really. I forgot about spacing the K, I did that on my Demon to clear the Indy intake and totally forgot about it till now.
It does not have to be a RB Block
If you have the link handy for your 493 build Paul I'd be interested in reading it.
Thanks,
Rick
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2283972
04/07/17 03:08 PM
04/07/17 03:08 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I figure my 511 six pack is well north of 600. It's been 10.90's at 4000# ( me in the car) running through exhaust and is nothing trick. Even has 50 year old gtx leaf springs. I'm sure more compression, camshaft in a lighter well set up car could really take it up a notch.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Recipe for 700hp six pack 440 or bigger- [Re: 70BIRD] #2284091
04/07/17 06:53 PM
04/07/17 06:53 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Originally Posted By 70BIRD
The intake had a stage II porting done by Hughes .
Paul
I did not think there was enough material for stage II porting on any six pack intakes with out modifying the runners and adding material on the top side of the runners for the larger ports.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284119
04/07/17 08:00 PM
04/07/17 08:00 PM
Cab_Burge Online work
Cab_Burge  Online Work
I put a low deck (400 block) 6 pack pump gas stroker motor together using a stock unported Eddy low deck six pack intake with stock type 440 carbs, the motor was 517 C.I. (4.375 bore x 4.300 stroke) with 10.29 to 1 compression with a set of Eddy RPM heads CNC ported by MCH, Comp Cams custom ground solid roller cam that was 260@.050 on the intake with .420 lobe lift and 266 @.050 on the exhaust with .409 lobe lift, Harland Sharp 1.65 ratio roller rockers that netted .700 at the retainers with checking springs.
This motor combination ran a bunch of 10.30 at 127.6 MPH through the 3.0 inch exhaust system on with a stock 6 pack air cleaner with dual stacked stock 6 pack Fram air cleaner elements in my 1971 Duster that weighed 3450 lbs. with me in it boogie
IHTHs thumbs
Re: Recipe for 700hp six pack 440 or bigger- [Re: Cab_Burge] #2284123
04/07/17 08:05 PM
04/07/17 08:05 PM
Sask, Can.
Sask, Can.
Thats respectable. What do you spin that thing too Cab?
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284124
04/07/17 08:14 PM
04/07/17 08:14 PM
I shifted at or above 7000 RPM after testing a bunch different shift RPM shruggy
I dyno tested that motor several different times on several different engine dynos, two different DTS and s Studka dyno, that motor made peak HP at 5500 and 5600 RPM with the six pack and it made peak torque at 4500 and 4600 RPM, depending on which dyno shruggy
I tried shifting it at 5500 RPM and then 6000 RPM, it ran faster at 6000 RPM so I then tried 6500, then 7000 and then 7500 RPM, it ran quicker and faster the higher I shifted that stupid motor confused I got scared of it above 7500 RPM so I decided 7000 to 7300 RPM was good enough for me thumbs It would repeat ET real well at those RPMs thumbs
That was a good car, lots of fun, especially on the street devil whistling grin
Re: Recipe for 700hp six pack 440 or bigger- [Re: GY3] #2284188
04/07/17 10:39 PM
04/07/17 10:39 PM
Superfreak
Superfreak
Originally Posted By GY3
I REALLY wanted to run a crossram on my '63 for the "look" more than anything. After seeing how it simply wasn't a good choice for my goals, I ended up going with a single 4 bbl.
The one concession I made was for everything to fit under the stock, flat hood.
Single carbs are too passé
Build it BIG!
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284332
04/08/17 11:30 AM
04/08/17 11:30 AM
Ohio
70BIRD Offline
70BIRD  Offline
Ohio
Rick, I barely know how to log in, don't know how to do a link but the post was from 06/07/10 in this forum.
Paul
Re: Recipe for 700hp six pack 440 or bigger- [Re: RATTRAP] #2284334
04/08/17 11:32 AM
04/08/17 11:32 AM
Ohio
70BIRD Offline
70BIRD  Offline
Ohio
I just pulled out the invoice from Hughes and it says Stage II porting. From the outside there was definitely no welding or material added.
Paul
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284373
04/08/17 01:12 PM
04/08/17 01:12 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Best et 6.27 at 3600+ pounds
Around 720hp. Just a smidge to tall for a shaker. Drove this car everywhere
Re: Recipe for 700hp six pack 440 or bigger- [Re: sixpackgut] #2284402
04/08/17 01:55 PM
04/08/17 01:55 PM
whistling
OP, this is the first tunnel ram six pack intake I've ever seen up
Mechanical carbs also up
Not a Weiand two piece SS or stock Eddy dual plane OEM intake work shruggy
Re: Recipe for 700hp six pack 440 or bigger- [Re: Cab_Burge] #2284407
04/08/17 02:12 PM
04/08/17 02:12 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Cab_Burge
... Not a Weiand two piece SS or stock Eddy dual plane OEM intake work shruggy
Ray better add some more pics of that intake before Cab's head implodes from curiosity. wink
Re: Recipe for 700hp six pack 440 or bigger- [Re: 70BIRD] #2284422
04/08/17 03:00 PM
04/08/17 03:00 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Paul
https://board.moparts.org/ubbthreads/ubbt...html#Post715629
Attached PDF document
6020509-DynoResults.pdf (139 downloads)
Re: Recipe for 700hp six pack 440 or bigger- [Re: 70BIRD] #2284442
04/08/17 03:39 PM
04/08/17 03:39 PM
Sask, Can.
Sask, Can.
Thanks Paul!
Ray- what was the test of your combo that it made 720?
Re: Recipe for 700hp six pack 440 or bigger- [Re: 70BIRD] #2284466
04/08/17 04:44 PM
04/08/17 04:44 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Paul
did you ever put any passes on this combo?
Re: Recipe for 700hp six pack 440 or bigger- [Re: 68 HEMI GTS] #2284494
04/08/17 06:12 PM
04/08/17 06:12 PM
Ohio
70BIRD Offline
70BIRD  Offline
Ohio
Unfortunately no, I would have had to drive to Norwalk and could never make it happen with friends, schedules, etc. Now I'm happy just going for rides around town.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 70BIRD] #2284495
04/08/17 06:15 PM
04/08/17 06:15 PM
How bad does it knock the tires loose on the street work devil
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284546
04/08/17 08:44 PM
04/08/17 08:44 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Originally Posted By 72demon416
Thanks Paul!
493. EZ heads MW port. Roller cam .630 265. 12-1. 185 cyl pressure. 9" converter. 3.55s with 28 or 4.10s with 30 tires.
I had 3 500 cfm carbs. Center carb was 4412 i modded
Re: Recipe for 700hp six pack 440 or bigger- [Re: sixpackgut] #2284557
04/08/17 09:14 PM
04/08/17 09:14 PM
Sask, Can.
Sask, Can.
Thanks Ray, looks like a nice combo.
So...this may sound retarded and I know there will be a myriad of answers but why did you guys choose the heads you chose? I look at the combos that are scattered around the internet and some guys use a Indy EZ, others a SR others a ??? What I mean is why stop there- why not say a 440-1 or larger? Is it that the ports are too large to be a efficient head for this power lever, pure overkill, a big price jump, or that other required parts to go with them becomes a little exotic or ???
I'm just sitting back looking at my original plan and saying why not go 440-1's or big easy with a modman that will fit them with EFI, on something like 570" 11.5-1, and a stick around .700 274-282. What are my plans biggest flaws?
