Page 21 of 48 1 2 19 20 21 22 23 47 48
Re: Modern Bullitt build [Re: Keepat] #2269483
03/14/17 06:19 PM
03/14/17 06:19 PM
mopar4don Offline
mopar4don  Offline
Originally Posted By Keepat
With the right side fender hung she is starting to look like a charger again :-)
Pat
That is one FINE looking charger!
Re: Modern Bullitt build [Re: Keepat] #2272659
03/19/17 11:41 PM
03/19/17 11:41 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Doors and fenders are closely aligned after a lot of massaging. Just need put the hood on and then I can start on the final gap alignment.
Pat
Re: Modern Bullitt build [Re: Keepat] #2274058
03/22/17 01:10 AM
03/22/17 01:10 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
After a few small modifications to both front fenders I installed the front valance and the hood. The trunk lid is next and then I'll start fine-tuning all the gaps.
Pat
Re: Modern Bullitt build [Re: Keepat] #2275627
03/24/17 10:33 PM
03/24/17 10:33 PM
Baltimore,MD
Bill_LBSR Offline
Bill_LBSR  Offline
Baltimore,MD
Your attention to detail and skills are impressive. This thread is motivation for me to finally start on my 69 charger project.
LBSR
Re: Modern Bullitt build [Re: Bill_LBSR] #2276368
03/26/17 10:10 AM
03/26/17 10:10 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Bill, Good to hear, I'll look foward to following your thread!
Thank You!
Pat
Re: Modern Bullitt build [Re: Keepat] #2276682
03/26/17 07:12 PM
03/26/17 07:12 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Nice work!!
You my friend have OCD!!! Would love to have you do my car.
Matt
Re: Modern Bullitt build [Re: MattW] #2277409
03/27/17 10:52 PM
03/27/17 10:52 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By MattW
Nice work!!
Matt
Matt,
I think most people on this site have OCD, Obsessive Chrysler Disorder ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2278645
03/30/17 12:25 AM
03/30/17 12:25 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Welded and filed the drivers door gaps. I set the sides at 5/32" leaving room for primer, sealer, base coat, and clearcoat. I had to weld a rod across the bottom of the door to close up the large factory gap that varied between 5/16" and 21/64. Now the bottom of the door is a consistent 7/32. Next up is the passenger door.
Pat
Re: Modern Bullitt build [Re: Keepat] #2278734
03/30/17 08:27 AM
03/30/17 08:27 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Excellent job Pat!
Re: Modern Bullitt build [Re: Keepat] #2279022
03/30/17 06:24 PM
03/30/17 06:24 PM
mopar4don Offline
mopar4don  Offline
Nice job Pat. say do you have any pics show that rod from the inside of the door? I think I may have to do this to my car.
Re: Modern Bullitt build [Re: Keepat] #2279254
03/31/17 12:13 AM
03/31/17 12:13 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Don, Here are a few pictures of the inside of the door.
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2279394
03/31/17 09:37 AM
03/31/17 09:37 AM
Virginia
Virginia
Pat - what kind of rod is that and how did you weld it (TIG or MIG)? TIG rod?
Re: Modern Bullitt build [Re: Keepat] #2279426
03/31/17 10:46 AM
03/31/17 10:46 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Larry, I used 1/8" tig welding rod (ER 70S-3)
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2279462
03/31/17 11:46 AM
03/31/17 11:46 AM
mopar4don Offline
mopar4don  Offline
WOW, I cant even tell you did anything!
Awsome job! I will remember this when I get to the same point.
Thank you
Re: Modern Bullitt build [Re: Keepat] #2283687
04/07/17 12:17 AM
04/07/17 12:17 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Passenger door gaps took a little more work. I had to add metal rod along the bottom edge and 1/2 of the front edge.
Pat
Re: Modern Bullitt build [Re: Keepat] #2283785
04/07/17 07:45 AM
04/07/17 07:45 AM
Virginia
Virginia
Pat - are you using TIG or MIG welding?
Re: Modern Bullitt build [Re: Keepat] #2283807
04/07/17 09:53 AM
04/07/17 09:53 AM
mopar4don Offline
mopar4don  Offline
Amazing work Pat!
Thank you so much for sharing your hard work!
It gives guys like me incentive to keep working on our projects!
The rod you used (ER 70S-3), Is this the same as the mig wire you are using?
Not sure if it matters?
Don
Re: Modern Bullitt build [Re: larry4406] #2284155
04/07/17 09:32 PM
04/07/17 09:32 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Larry, All Mig welding. I'm still in the practicing stages of Tig welding. Tig welding is sort of like playing drums, you use your hands and feet and when it's done right you make a cool sound. Right now my Tig welding sounds like a monkey playing the bongos ;-)
Pat
Re: Modern Bullitt build [Re: mopar4don] #2284160
04/07/17 09:35 PM
04/07/17 09:35 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted By mopar4don
Amazing work Pat!
Don
Don,
Yes, same type of wire I use in my Mig welder, just a lot smaller.
Thank you
Pat
Re: Modern Bullitt build [Re: Keepat] #2284179
04/07/17 10:23 PM
04/07/17 10:23 PM
Virginia
Virginia
Thanks Pat. I'm trying to learn MIG.
