Re: Truck Dana 60 to car conversion
[Re: 6pakdakota]
#2282247
04/04/17 02:54 PM
04/04/17 02:54 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Most of the truck Danas are 3.125" or 3.25" axle tubes. I have 2 truck Danas under 2 different road runners at home. Both have 3.125" tubes...one from a ford truck and one from a dodge truck.
6packdak...I'm no help w/ the newer van Danas. I saw several of those myself in the junkyard and wondered the same thing. Ended up finding a couple of older ones and got them instead.
[Re: MR_P_BODY]
#2282259
04/04/17 03:07 PM
04/04/17 03:07 PM
Posts: 156 michigan
6pakdakota
michigan
Measure the OD of the tube to see if its the heavy 3.250 I will have to go back later this week to check. They definitely aren't any bigger than 3.25
[Re: Moparmatts72]
#2282325
04/04/17 05:04 PM
04/04/17 05:04 PM
dogdays
The semi-floating Dana 60s under Ford vans and pickups from 1981 - 1982, (pickups) and 1981 - 1983, (vans), are 61s.
There's a guy on the Q&A page looking for one.
R.
[Re: 6pakdakota]
#2282341
04/04/17 05:29 PM
04/04/17 05:29 PM
Posts: 499 Gettysburg Pa
roadrunnerreds
Gettysburg Pa
Thats what i used in my 65 dart ford truck dana but i cut off a set of the wide factory ends off 8 3/4 and used them on my dana
[Re: 6pakdakota]
#2282434
04/04/17 08:40 PM
04/04/17 08:40 PM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
My buddy had a truck Dana- he cut to exact same width as his E body rear, welded 8 3/4 ends on and slipped his axles from his 8 3/4 in it.... I have a couple Dodge motorhomes with Danas under the rear.... hmmmm Truck housings have no pinion snubber holes.....
CrAzYMoPaRGuY
[Re: 6pakdakota]
#2282447
04/04/17 08:59 PM
04/04/17 08:59 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
The Dana I put under my 65 Plymouth B-Body came out of a 78 ford truck. The 35 splines out of my 8-3/4 I tore up went right in my Dana axle
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#2282466
04/04/17 09:25 PM
04/04/17 09:25 PM
CrAzYMoPaRGuY
Canada
The Dana I put under my 65 Plymouth B-Body came out of a 78 ford truck. The 35 splines out of my 8-3/4 I tore up went right in my Dana axle Unless I'm wrong my buddy had 30 spline stock axles which slid right in....?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2282489
04/04/17 10:04 PM
04/04/17 10:04 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The Dana I put under my 65 Plymouth B-Body came out of a 78 ford truck. The 35 splines out of my 8-3/4 I tore up went right in my Dana axle Unless I'm wrong my buddy had 30 spline stock axles which slid right in....? 30 is stock.. most guys run the 35.. bigger is better
[Re: CrAzYMoPaRGuY]
#2282708
04/05/17 10:19 AM
04/05/17 10:19 AM
mopar65
The Dana I put under my 65 Plymouth B-Body came out of a 78 ford truck. The 35 splines out of my 8-3/4 I tore up went right in my Dana axle Unless I'm wrong my buddy had 30 spline stock axles which slid right in....? I was runing 35 spline moser axles in my 8-3/4. I put a 35 spline spool in. My Dana 60
support our troops
[Re: 6pakdakota]
#2282712
04/05/17 10:23 AM
04/05/17 10:23 AM
mopar65
Also if you are runing the stock Dana suregrip and latter on want to change to 35 spline axles., but want to keep the sure grip.Doctor Diff sells 35 spline spider side gears
support our troops
[Re: 6pakdakota]
#2285210
04/10/17 10:35 AM
04/10/17 10:35 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I used an early 70s ford truck with 3.73s in my belvedere. I bought a jig on ebay and narrowed and put on car ends. I could have got it done for about the same cost as the jig, but I've done a couple others, so it's paid for itself.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2285213
04/10/17 10:41 AM
04/10/17 10:41 AM
Posts: 4,687 Wichita
GY3
Wichita
I used an early 70s ford truck with 3.73s in my belvedere. I bought a jig on ebay and narrowed and put on car ends. I could have got it done for about the same cost as the jig, but I've done a couple others, so it's paid for itself. I have a race fabrication shop less than 15 minutes from me so having them weld up the car ends and setup the ring and pinion was a no brainer! I have ~$900 in a Dana 60 that was cut to my width with aftermarket axles and a spool!
[Re: 6pakdakota]
#2285399
04/10/17 06:22 PM
04/10/17 06:22 PM
Silver70
Rust Belt, SW PA
I usually look around for good used 35 spline axles around the length I can use... Less the jig, my rear cost around 300 with a new spool. 35 spline strange axles you couldn't even tell were used. I'm cheap, so 900 would be way too much for me!
