Air shock question E body #2282152
04/04/17 12:44 PM
04/04/17 12:44 PM
Finally a HUSKER again
Moparnut426 Offline OP
Father in law wanted the older look like when he was in high school. Bought brand new air shocks, small air lines with little o rings, and plastic everything. Darn things wont hold air for a full day. Ive used soap and water and cant find a leak. Have any of you guys found a cure or dealt with this issue?
Only thing I can think of to do is fill each shock individually
Kasey
Re: Air shock question E body [Re: Moparnut426] #2282160
04/04/17 12:55 PM
04/04/17 12:55 PM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
Did you check the shock air bladder with soapy water? Might have a leak there rather than on the lines and couplings.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: Air shock question E body [Re: Moparnut426] #2282193
04/04/17 01:30 PM
04/04/17 01:30 PM
I did and did not see anything. I wonder if they are leaking internally and the air could be leaking out the shock tube seals?
I know its a pretty bad leak as they loose all their air over night.
Re: Air shock question E body [Re: Moparnut426] #2282811
04/05/17 01:45 PM
04/05/17 01:45 PM
Chicago
PurpleBeeper Offline
Chicago
Well, the "little air pixies" didn't come and steal it. There's a leak somewhere. I think you should split the lines anyway to reduce rear-end roll in corners. That'd help you narrow it down to one side or the other.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Air shock question E body [Re: PurpleBeeper] #2282850
04/05/17 02:38 PM
04/05/17 02:38 PM
Indianapolis, IN
B5Cuda440-6 Offline
B5Cuda440-6  Offline
Indianapolis, IN
iagree
