Re: Tube Chassis cars, what to look for?
[Re: rebel]
#2282057
04/04/17 09:07 AM
04/04/17 09:07 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
How old is it? If you are planning on getting a cert, NHRA changed wall thicknesses on M/S a bunch of years ago. Check welds, eyeball up squareness. Sit in it and make sure you fit.
[image][/image]
[Re: RTSE4ME]
#2282077
04/04/17 10:22 AM
04/04/17 10:22 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm not sure how your rules are were you race but I would get a rule book or chassis spec sheet. My mild steel Daytona was well built and would easily pass 8.50 cert. When I wanted to lower it to 7.50 we figured 4 bars but when it was on a host it actually needed 8 as some of the rules changed over the years. They were all small bars and only cost 400-500 dollars but it could have gotten crazy real fast. Hopefully he one you are looking at has struts already and a good rearend or once again it will cost big money to get track ready. Sometimes a deal isn't a deal.
[Re: rebel]
#2282360
04/04/17 05:53 PM
04/04/17 05:53 PM
Posts: 52,972 Romeo MI
MR_P_BODY
When I was building chassis's we were allowed to sleeve tubes but they had to be welded also with at least 2 added puddle welds to show that they were welded there.. I dont know if that rule still stands or not.. the books will tell you
[Re: rebel]
#2282676
04/05/17 08:57 AM
04/05/17 08:57 AM
sgcuda
I think the rear x brace should have landed on top of the frame rails, not on the inside. In the upper left of the pic, it looks like the x brace is spliced to the main hoop. I would question that area.
[image][/image]
[Re: rebel]
#2282677
04/05/17 08:59 AM
04/05/17 08:59 AM
sgcuda
And the rear down bars are welded on a plate, that is welded to the rear shock crossmember? I don't know about that, either.
[image][/image]
[Re: sgcuda]
#2282916
04/05/17 04:29 PM
04/05/17 04:29 PM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
And the rear down bars are welded on a plate, that is welded to the rear shock crossmember? I don't know about that, either. From the main hoop back is all wrong ...not that it won't pass tech or cert at about 90% of the tracks. But if this car gets in a high speed inpact those rear struts are leaving the scene for sure.... Good catch on all of those.
[Re: rebel]
#2283994
04/07/17 03:45 PM
04/07/17 03:45 PM
Posts: 11,653 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You will have more time and money in fixing that than building one from scratch. And it will still be a hacked up car when you're done. Good used cars are cheap now. If it doesn't have a current tag on it, I would pass, regardless what it looks like. That wouldn't pass with any inspectors I know. The stories I could tell about projects that started out with something like that to save money. Most of the time it ends up being thrown in the trash and maybe saving a rear end and some brakes and wheels out of it. Not bashing. I just hate to see people waste money.
[Re: rebel]
#2284002
04/07/17 04:08 PM
04/07/17 04:08 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
i'm going to check out a tube chassis car next week, i've always had back halfed street cars so what does one look for with a tube chassis? The car has box section in the middle with tubed extentions front & rear. A steel shell has been fitted & a glass front clip. A Mark Williams fabricated 9 3/4 differential with Strange case & floater axles. It's 4 bar rear, Front struts & a Strange Steering rack fitted. Some tin work still needs doing but has a floor tunnel over the trans & a driveshaft loop inside the car. This is an unfinished project from 2x previous owners. Both owners had gone the Hemi Route so BBM is an easy fit. Since its never been a finished racecar, what things would i need to pay attention to when i'm looking at everything? Anybody got pics of theirs or someones project? it's not quite a Pro Mod but its getting close. That thing is miles away from being a ProMod! If I were you I would pass on this thing. How fast are you wanting to go? I doubt that chassis would pass any cert.
[Re: Biginchmopar]
#2284016
04/07/17 04:34 PM
04/07/17 04:34 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
8.50 Cert that I changed to 6.0 Cert What spec is that? I see 2x3 main rails, those are only good to 7.50, or did you add redundant chromoly rails?
