Page 3 of 8 1 2 3 4 5 6 7 8
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: 68HemiB] #2281055
04/02/17 06:42 PM
04/02/17 06:42 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Originally Posted By 68HemiB
Originally Posted By MuuMuu101
...My Camaro front spoiler was destroyed by a couple cones...
The way I understand autocross, you are supposed to drive around the cones. shruggy
grin
Why? It takes longer.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: amxautox] #2281264
04/03/17 12:08 AM
04/03/17 12:08 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
grin
'cause if you don't, you break your spoiler, duh tonguue
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: Skeptic] #2281277
04/03/17 12:23 AM
04/03/17 12:23 AM
amxautox Offline
amxautox  Offline
Oh ya, dats right. grin
Tom
author unknown
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: amxautox] #2281284
04/03/17 12:32 AM
04/03/17 12:32 AM
Mesa, Arizona
dart4forte Online boogie
dart4forte  Online Boogie
Mesa, Arizona
Toms nickname is Cone Killa boogie
Abe Lincoln
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: dart4forte] #2281285
04/03/17 12:33 AM
04/03/17 12:33 AM
amxautox Offline
amxautox  Offline
Been known for that, a time or 20. laugh2
There is at least a couple marks on the SS/T truck, and the AMX from the cones. And I left at least a few marks on the cones. One cone was pretty messed up too when it got caught between the tire and the frame and inner fender on the AMX. drive laugh2
Tom
author unknown
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: MuuMuu101] #2281900
04/03/17 11:05 PM
04/03/17 11:05 PM
so cal
alltime Offline OP
alltime  Offline OP
so cal
MUUMUU,
How much camber do you have? With more neg camber it will move the top of the tire in.
If you have a rear sway bar you will want to disconnect on link for Big Willow if you are already noticing a loose condition in Solo II.
AutocrossCuda can confirm.
Are all 4 tires the same size? if so you can rotate.
Maybe we will give you neg camber at the track!
Tim
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2281912
04/03/17 11:12 PM
04/03/17 11:12 PM
so cal
alltime Offline OP
alltime  Offline OP
so cal
Trying out our new tires for fender clearance on the street. But Willow could be a different story.
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2281981
04/04/17 01:29 AM
04/04/17 01:29 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
That AMX looks bad ass! Reminds me of the factory race car that had the Daisy mags.
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2281992
04/04/17 01:49 AM
04/04/17 01:49 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Originally Posted By alltime
MUUMUU,
Tim
Not sure on neg camber numbers, but I agree, that should help.
Why would I want to remove the rear sway bar?
All 4 tires are the same size, but the front and rear wheels have different offsets so I can rotate them front to back.
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2282024
04/04/17 03:48 AM
04/04/17 03:48 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
A car that feels slightly loose (Traction-wise) at the rear will be MUCH more likely to spin as it goes faster. An oversteer condition is exponential.
Oversteer helps a car make tighter turns in the autocross and a spin out at such low speeds rarely causes lasting damage. If the tail end gets loose in a turn on a road course where other cars are nearby, bent sheet metal and apologies are likely!
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2282119
04/04/17 12:02 PM
04/04/17 12:02 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
iagree
That's the bottom line or Alltime will put a big rookie X on the back of your car, just like at the races. eek
But, but why? you ask?
It's as much about driving as it is about the car. I'll let professional race car driver and National Solo champion Randy Pobst explain Why Understeer is Your Friend
On the car side:
If you think Frankenduster is speaking from a unique point of view, Steve will tell you from personal experience on that very track. I can tell you from personal experience on roadways (I was younger once). Mike Ritz can tell you from personal experience racing a '66. The list goes on... With the a-bodies, start with no rear bar for high speed. Then as decide if adding a little bar (soft) is wanted.
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2282138
04/04/17 12:30 PM
04/04/17 12:30 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
More on driving
Tipping, flipping and even occassionally driving over cones with the wheels will happen. You've got to come as close as possible to some of the key cones to make the distance shorter and the turns smooth.
Center punching cones is bad. There's a few causes and indicates potential problems on a high speed, higher risk track.
1. Looking at the cones. The car will go where you look. You must look ahead to where you want the car to go.
2. Course is unclear. The most important thing to do at any event is learn the course. Knowing where to go makes it much easier to look ahead.
3. Overdriving the front wheels. Timing the right amount of speed, braking and power is the goal. Too much speed in any turn, and autocrosses are all turns, and the car goes straight because the front tires are overloaded.
A slalom is the one place where it is more likely that too much speed will not centerpunch a cone. In a slalom, too much speed more often results in fishtail and around you go.
Looking where you want the car to go is really really important to learn to do. It helps driving and just as important it will help when crashing. After all, you don't want to crash into the tree eek, but the hopefully safer grassy area next to the trees.
Pobst "On Being a Good Crasher"
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: Mattax] #2282161
04/04/17 12:57 PM
04/04/17 12:57 PM
amxautox Offline
amxautox  Offline
Yup. At the autocross practice one day the car got loose in the slalom and was fishtailing bad. Got the car straightened out and on around the course. One guy on the sidelines told me I was headed towards a light pole, and did I see it. I said "Yes, but I figured if I watched the pole I'd hit it, so I ignored it." That worked and I missed it. boogie
Tom
author unknown
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2282198
04/04/17 01:37 PM
04/04/17 01:37 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Gotchya. We can remove the bar on track day. Keeping my eyes looking ahead at the next turn is probably the most challenging part for me. At the next autocross, I'll probably try painter's taping the bottom of my winshield to force me to look ahead.
I spun my Scion out at Willow last year. I had stickier tires up front. Same concept with the sway bars.
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2282629
04/05/17 01:33 AM
04/05/17 01:33 AM
so cal
alltime Offline OP
alltime  Offline OP
so cal
BBQ and beer Wednesday 2pm. Meet and unload the cars. Round table with other drivers, and BS session headed up by Chrysler Chassis and Race Engineer Bill Surber, liaison to Richard Petty Enterprises from 1968-1976...and on , and on.
Car List:
1958 Plymouth Hardtop, Phoenix
'15 Hellcat
'17 Viper
'64 Nova
'73 Cuda
'70 Challenger
ZR1 Vette
'15 Challenger
'69 Daytona
'70 Cuda
'69 AMX
911 Turbo S
'73 Charger
911 S
'67 Coronet, Oklahoma
'12 Challenger
'15 Mustang Gt
'16 Z06
Ferrari Modena
'68 Dart GT ready to rock
'95 Mustang
Daytona Coupe
'69 Camaro
Hertz rent-a-racer
'70 TA Challenger
'70 Chevelle
Comp Coupe Viper
GT3
Comp Coupe Viper
Hellcat
Audi TT
Audi TT quattro
'12 VW GTI
'68 Valiant "Red Brick"
'65 Dart, Vancouver, Wa
'66 Dart
'69 AMX
'16 Z06
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2282639
04/05/17 02:09 AM
04/05/17 02:09 AM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
I won't be in tomorrow until about 9-11pm.
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: MuuMuu101] #2282714
04/05/17 10:27 AM
04/05/17 10:27 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
In regard to looking ahead, I am coming from a background in sportbike racing, but the concepts carry over.
On the straight, I would be looking at the corner entry, once I entered the corner I was focused on the apex, then the corner exit, then the entry for the next turn. Keeping your point of focus as far forward as possibly really helps slow everything down and helps you get set up. This is not to say I wasn't paying attention to brake markers, traffic, surface features, etc. with my periphery, but my focus was always very far ahead.
Have fun! I'm jealous...weather hasn't warmed up enough for anything here yet...I have to live through you guys
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2282770
04/05/17 12:34 PM
04/05/17 12:34 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
I'll be there around 4-5pm
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: alltime] #2282771
04/05/17 12:37 PM
04/05/17 12:37 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I'm gonna bring my 4 pad Longacre digital scales.
So I can weigh your Mopar's weight balance
Re: Spring Fling Speed Festival XI, Thursday, April 6th, 2017 [Re: autoxcuda] #2282787
04/05/17 01:07 PM
04/05/17 01:07 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Yes please! Haha!
Thanks so much!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
