Re: Big Block Dip stick/tube education
[Re: dvw]
#228079
02/18/09 05:54 PM
02/18/09 05:54 PM
Posts: 33,005 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
The best way to fit them is drill the block hole slightly larger. Then seal the tube with RTV. You'll be a whole lot happier. You can do it even with the engine assembled. Just flush the pan with solvent. Doug
Bad idea. The block doesn't ever need to be drilled out to accept a dipstick tube. All that does is cause leaks from a loose tube.
[Re: dvw]
#228080
02/18/09 07:47 PM
02/18/09 07:47 PM
Posts: 6,444 Abilene, Texas
fastmark
Abilene, Texas
I don't think this is a good idea. Then you have a block with a hole too large. I have installed lots of dipstick tubes and have never had any problem installing them. I would never drill and then wash cast iron shaving down in the oil pan. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: fastmark]
#228081
02/19/09 10:07 AM
02/19/09 10:07 AM
Posts: 227 upstate NY 12839
TMBOOTS
upstate NY 12839
I would try putting the tube in the freezer for a half hour and it should install easier in to the warmer block.. Just a thought!!
[Re: stumpy]
#228082
02/19/09 05:56 PM
02/19/09 05:56 PM
Posts: 9,894 MI, usa
dvw
MI, usa
I have built every big or small block motor that way since 82. Not one has leaked. The shavings will rinse out. I didn't say drill the hole to 1/2".,just a slip fit. Many of the new GM factory dipsticks are slip fit. Yes,I work on the dark side. 27 years as a dealer tech. If it comes back I do it for free. Thats why I make sure its right the first time Doug
