Re: BB Victor Heads Update
[Re: MoParFish]
#2281478
04/03/17 12:39 PM
04/03/17 12:39 PM
Thumperdart
State of confusion
Here's my Victor head update. Fuel pump quit 1000 ft out first round last Sunday at Summit race #4 Famoso. Didn't catch it in time = torched between 3&5. 440/512 OOTB MW Victors Weighs 3725 and has been 10.18 and 1.40 60ft. Has been pretty much a turn key combo since 2013 going quite a few rounds and some street action. Will fix head for sure but looking at other options too so will keep an eye on head threads like this. Sorry for the hijac Sorry to see this............. Do you have a WB?
[Re: ccdave]
#2281488
04/03/17 12:50 PM
04/03/17 12:50 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Ouch!!
Fel-pro 1009's....... That's just askin' for it.
[Re: fast68plymouth]
#2281559
04/03/17 02:30 PM
04/03/17 02:30 PM
Posts: 485 Central California
MoParFish
Central California
Ouch!!
Fel-pro 1009's....... That's just askin' for it. I hear ya Dwayne, they are 17059 marine gaskets but I'm sure same category. When it went, it sounded like dropping a box of silverware on the floor. As I was going for the kill switch I glanced at the fuel pressure and was bouncing off zero. Have an older WB Dom but, wasn't looking at it that run. Had been around 12.5 pulling.
[Re: ccdave]
#2281804
04/03/17 08:03 PM
04/03/17 08:03 PM
Posts: 1,506 TN
SCATPACK 1
TN
Fish I had a set of Zeeker heads that burned thru in the same spot. Had them welded up an re machined and never looked back. Also switched to copper head gaskets on mine and have not been an issue either.
Old Geezer Racing
[Re: SCATPACK 1]
#2281884
04/03/17 10:37 PM
04/03/17 10:37 PM
Posts: 1,784 PA
W5DART66
PA
So I am working on CNC program for this head right now. Today we flowed intake port for first time chamber just blended into valve job. More work to be done..... Air speed little high 330 down the center of the port and 398 average over the short turn. Well here are some pictures
[Re: W5DART66]
#2281982
04/04/17 01:31 AM
04/04/17 01:31 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
So I am working on CNC program for this head right now. Today we flowed intake port for first time chamber just blended into valve job. More work to be done..... Air speed little high 330 down the center of the port and 398 average over the short turn. Well here are some pictures For size reference, is that a standard MW port window?
[Re: W5DART66]
#2282058
04/04/17 09:17 AM
04/04/17 09:17 AM
Posts: 1,051 The Great White North
RAMM
Brett you're going to want to look at I.H. on these heads. It's great that you're observing big flow rates but practical valve lift is sub .800" unless you're moving rockers around. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: W5DART66]
#2282081
04/04/17 10:29 AM
04/04/17 10:29 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
So I am working on CNC program for this head right now. Today we flowed intake port for first time chamber just blended into valve job. More work to be done..... Air speed little high 330 down the center of the port and 398 average over the short turn. Well here are some pictures Wow! Is this with a 2.250 valve?
[Re: RAMM]
#2282085
04/04/17 10:31 AM
04/04/17 10:31 AM
GTS340
Romulus, MI
Brett you're going to want to look at I.H. on these heads. It's great that you're observing big flow rates but practical valve lift is sub .800" unless you're moving rockers around. J.Rob My guess would be longer valves and paired shaft rockers are part of the plan
[Re: W5DART66]
#2282133
04/04/17 12:19 PM
04/04/17 12:19 PM
fast68plymouth
So. Burlington, Vt.
Anyone care to share some data for what's out in market for this head?
The port I have right now will support 1000 HP I am sure. I guess I would answer that with a question..... What type of build do you envision using heads like that and making 900-1000hp? Are they going to need any other "special" parts that will be required to be able to take advantage of the heads in that configuration?(intake manifold, milling for Jesel, longer valves, etc) Then, when it's all said and done, does it make that power easier and/or less expensively than the heads it will be competing against? The reason I bring this up is, B1 heads. Easily can make 1000hp...... Yet they aren't as popular as the much more user friendly Indy stuff. I'm just being the devils advocate here....... If you're trying to develope something that has a reasonable amount of mass appeal(rather than just being more or less a "science experiment"), then it needs to have the support pieces be readily available so it can really compete in the marketplace. I haven't had one in my hands, but Hughes sells a cnc ported MW version of that head they claim flows 400.
