Wingnut ID help needed #2279152
03/30/17 10:14 PM
03/30/17 10:14 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Was told this could be a shaker base hold down? Any help would be appreciated. thanks!
Re: Wingnut ID help needed [Re: Mopucky] #2279181
03/30/17 10:59 PM
03/30/17 10:59 PM
MD
floyd Online content
floyd  Online Content
MD
Yep - 383 baseplate only. There is a funky hexagonal rod with threaded ends that stabilizes the assembly. The wing nut you have secures the baseplate to the top end of the rod.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/566440/1.html
Re: Wingnut ID help needed [Re: Mopucky] #2279198
03/30/17 11:18 PM
03/30/17 11:18 PM
New York
Mopucky Offline OP
Mopucky  Offline OP
New York
Thanks so much! I couldn't find what it fit, was searching 340 parts.
Re: Wingnut ID help needed [Re: Mopucky] #2279442
03/31/17 11:17 AM
03/31/17 11:17 AM
MarkMcDonald Offline
69 N96 4 barrel also! Holds the baseplate to the carb as the lid has two wing nuts holding it to the baseplate. I had a N96 69 GTX in the late 70s and it was on the car when I removed the air cleaner the first time.
